Loss of power in overdrive. - JeepForum.com
 3Likes
  • 1 Post By TheBoogieman
  • 1 Post By Jerry Bransford
post #1 of 9 Old 06-12-2021, 08:34 PM Thread Starter
maintman40
2004 4.0
Starts and runs good. Wont gain speed in overdrive. Seems very sluggish. New air filter, spark plugs.
maintman40 is offline
post #2 of 9 Old 06-13-2021, 11:38 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Your 42RLE's overdrive ratio reduces the engine rpms so much that it will barely accelerate in overdrive. Its OD ratio is .69 so the engine rpms are reduced to 69% of what they were in 3rd gear. To really accelerate you need to get out of Overdrive by either stepping hard on the gas or temporarily switching the Overdrive off.
Something else that will cause a lack of power is having installed larger tires which further reduces engine rpms. Bigger tires can kill performance and the only fix is to regear both axles to a lower ratio to get the engine rpms back up to where they should be.
What size tires are you running?
Jerry Bransford is offline
post #3 of 9 Old 06-13-2021, 03:09 PM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
You might have 3.07 gears also.
Jerry Bransford likes this.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
2003' Rubicon/Zone 4.25" combo lift with Rancho RS5000X shocks/ Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
TheBoogieman is offline
post #4 of 9 Old 06-13-2021, 03:16 PM
Jerry Bransford
Administrator
X2, your TJ would be a real dog acceleration-wise with 3.07 in the axles.
You should be able to tell what your axle ratio is by looking at the steel ratio tag bolted onto the 9 o'clock position of your diff covers. This tag is indicating a 3.73 ratio inside the axle. No worries if yours says 3.08 or 3.74, the front and rear axle ratios are .01 different on all but Rubicons.
TheBoogieman likes this.
post #5 of 9 Old 06-13-2021, 03:33 PM
dbbd1
dbbd1's Avatar
Add to that above too, that maybe the transmission kick-down cable (I forgot the name right now) may not be adjusted correctly.
The opinions of worthless people, are worthless.
The only problem that you have with anyone in this world, is what you expect of them.
Society is no match for a stupid person.
"Life Is tough but it is tougher when you are stupid"
-John Wayne
dbbd1 is offline
post #6 of 9 Old 06-13-2021, 05:33 PM
Jerry Bransford
Administrator
While the earlier 32RH had a TV (throttle valve) aka kickdown cable, the OP's 42RLE is fully electronic/computer controlled and has no kickdown cable.
post #7 of 9 Old 06-14-2021, 01:10 PM
rsurran
rsurran's Avatar
My 2003 had 3.07 gears on 33 inch tires. Luckily it was a 5 speed stick. I posted similar to you when I first got it. After I got educated I never ran it in 5th gear (OD) except on rare occasions of flat level roads. Jeep did fine in 4th.
2003 TJ 4.0L Freedom Edition, Flame Red, 5 spd., CAI, Warn, stinger, Hella/KC trail lights.
2013 JK Sport Black, Auto Trans, Bone Stock
Dick Surran
"When you stop contributing you are just taking up space."
rsurran is offline
post #8 of 9 Old 06-14-2021, 01:48 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
2020 J-Series Truck
Jerry pointed out the 0.69 overdrive ratio.
In other words, you are only putting 69% power to the wheels when in overdrive.
You are around 130hp at the rear wheels stock and this is around 4,500 RPM. In overdrive you'll put about 90hp to the rear wheels at 4,500 RPM, but you'll never see that RPM in overdrive. 4,500 rpm is 190mph with 3.07 gears or 155mph with 3.73 gears.
Long story short, you're below 90hp at the rear wheels in overdrive.
Wheelin98TJ is offline
post #9 of 9 Old 06-14-2021, 05:45 PM
TheBoogieman
Well that's depressing info.
