Losing power - JeepForum.com
post #1 of 3 Old 02-02-2017, 07:43 PM Thread Starter
bj26pro
bj26pro's Avatar
Losing power
My jeep 06 lj rubi is acting up... open door lights come on go the turn key and as soon as I go to hit the starter it looses all power. Interior lights go out, gauges bounce around and have no power at all except the wiring I have done for lights. I wire wheeled the battery terminals and all wire ends that attach to the terminals. I'm thinking it could be a bad ground somewhere but not sure where to start. After a few try's power returns and can start it.
https://youtu.be/K4aUEqqC-S0
bj26pro is offline
post #2 of 3 Old 02-03-2017, 12:14 AM
KG6KJS
KG6KJS's Avatar
Mine was doing the same thing. I couldn't figure it out, until it finally wouldn't start at all. Ended up being the ignition actuator pin. The tiny piece of metal that turns the ignition switch had broken. It is easy to pull the ignition switch to check.
https://www.jeepforum.com/forum/f9/ig...ge=1&_k=2m2y5b
Worth a shot or look. Good Luck!
2006 Jeep LJ "Fred"
KG6KJS is offline
post #3 of 3 Old 02-03-2017, 02:30 AM
Laredo-Alex
I would say that the life of your battery is over! Try to reload it, maybe it will work again! Good luck!!!
Proud member of the LJ-Family :) => 2005 LJ Rubicon - YES!
Laredo-Alex is offline
