Looking for guidance after a PCM swap... - JeepForum.com
post #1 of 18 Old 11-27-2018, 01:14 AM Thread Starter
Kokala
I am no mechanic and have learned a lot form the forums. After much research and testing using these forums as reference, I decided my PCM was failing. Symptoms were, fuel pump not shutting off after 3 seconds coupled with the gauge cluster not waking up until after several attempts at turning the key on and off. I decided it was the PCM because after replacing the fuel pump the problem persisted and when the gauge cluster would finally wake up the Jeep would fire and run like a champ. Finally, the Jeep quit starting all together. It has sat for about 4 months.
After installing the new PCM the fuel pump and gauge cluster behave normally. The jeep turns over strong and starts but dies instantly. If I hit the gas I can get one or two revs out of it before it dies. It sounds normal in that instant. No sputter, it shuts off like the key was removed. I have cleaned the IAC and replaced the TPS after getting the code P0123. I back probed the TPS before replacing it and had voltage from .8 to 3.9 from closed to open. The new TPS gives the same reading.
Any thoughts? I have a sinking feeling the PCM is still the issue... Any help is appreciated!
`97 Wrangler Sport
4.0 L
Manual
No mods
Stock
Kokala is offline
post #2 of 18 Old 11-27-2018, 05:50 AM
tsc
Any chance your rig has sentry key? Where did the new pcm come from?
tsc is offline
post #3 of 18 Old 11-27-2018, 06:47 AM
2jhanna
This was my first thought also, either his rig, or the new pcm.
Another thought is to go back to your old pcm and see if symptoms go back to original.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #4 of 18 Old 11-27-2018, 12:55 PM Thread Starter
Kokala
I too was thinking security system.
My rig does not have any security key. I'm not familiar with how they are integrated when present. Is it possible the PCM is looking for one?
I went back to the original PCM and got the same symptoms. Fuel pump running continuously, or running for 3 seconds pausing then running continuously. Fuel and voltage gauge doe not function on the cycles when the fuel pump runs continuously but will "wake up" occasionally. Crank but no start.
Installing the new PCM after that, the Jeep starts up strong and dies nearly instantly. I can still get one or two good revs.
PCM is from Flagship One. The unit they sent has a factory code on it that matches a 96 Cherokee, automatic, and different engine size. I contacted them before installing and they assured me the internals matched what I had purchased....... Looks like I'm a sucker.
I'm am probably going to return this one as I'm pretty sure it's the problem. Is there any other reputable resource for PCM's these days? It doesn't look like Cardone makes them any more, so RockAuto and the chain stores have none available.
Kokala is offline
post #5 of 18 Old 11-27-2018, 03:52 PM
Jonny Jeep
Jonny Jeep's Avatar
97s didn't have sentry key so if the new PCM is a 97 or is programmed as a 97 it shouldn't be an issue. If it's a 98-99 PCM, the 97 dash doesn't have the sentry key light so I don't know how you'd easily check if the PCM has sentry key programmed.
As the Jeep has been sat for four months could it be the battery has enough charge to start but is then low enough that the engine will struggle to run?
Jonny Jeep is offline
post #6 of 18 Old 11-27-2018, 06:44 PM
rcroane
Reviews for Flagship One are really bad. Most info I have read says buying from any internet PCM builder is a real crap shoot. There is one guy who has posted having good luck with Modulegods. Have you tried sourcing one remanufactured by Chrysler?
rcroane is offline
post #7 of 18 Old 11-27-2018, 07:30 PM Thread Starter
Kokala
I sure was hoping there was a way to determine if the PCM was looking for a sentry key.
I have it at AutoZone for an overnight charge and test. Battery is 3 years old and right at the end of the Costco warranty.
I was super hesitant to try from them based on their reviews. Their ebay store has them at over 95% so I thought that might be a safer, proven channel. Everyone I looked at seemed like a crap shoot. I never stumbled across a source by Chrysler. Mopar doesn't have any. I'll take a look a Modulegods in the event I return this one. Without quality rebuilders, when these computers go does that mean our trucks just die?
Kokala is offline
post #8 of 18 Old 11-28-2018, 06:50 PM
rcroane
You'll need to go through a dealer to get a Chrysler re-manufactured one. Not sure about your year, but really tough to find one for '05's and '06's.
rcroane is offline
post #9 of 18 Old 11-28-2018, 09:44 PM Thread Starter
Kokala
Welp... no luck with leaving my battery at the store overnight. They say it load tested fine, 89%. Jeep cranked and started again but died.
At this point I'm stuck. Googling the symptoms I keep getting SKIM key which I don't have. I'd be willing to throw $80 at a MAP or IAC if anyone else thinks it's worth it but I am not sure they are the issue.
I'm going to start looking for a new PCM again. I'll check with my dealer for sure.
Anyone have a source for a PCM that fits a `97? Used or remanufactured?
Anyone used a service that has repaired their PCM they can recommend?
Kokala is offline
post #10 of 18 Old 11-30-2018, 10:44 AM
LafitteJeep
LafitteJeep's Avatar
I am that one guy that used ModuleGods and over 1600 miles and running fine.
LafitteJeep is offline
post #11 of 18 Old 11-30-2018, 10:46 AM
LafitteJeep
ModuleGods did mine over 1600 miles ago. I was under a different user name. I would also check the ASD relay. Swap it out for another just to see if the engine will stay running.
post #12 of 18 Old 12-01-2018, 09:17 PM
chevymad
Had a jeep come in recently that had the pcm replaced. Same symptoms. New pcm had been flashed with skim enabled even though the jeep had no skim. Trailered it to the dealer for a reflash and it works.
chevymad is offline
post #13 of 18 Old 03-07-2019, 11:06 AM
Andyduck
Autozone had a good PCM for me.It took three days to get it though.You might try a new cranckshaft position sensor.
Andyduck is offline
post #14 of 18 Old 03-07-2019, 04:47 PM
dbbd1
dbbd1's Avatar
How much was yours from a-zone?
The opinions of worthless people, are worthless.
The only problem that you have with anyone in this world, is what you expect of them.
Society is no match for a stupid person.
"Life Is tough but it is tougher when you are stupid"
-John Wayne
dbbd1 is offline
post #15 of 18 Old 03-08-2019, 09:44 PM
Andyduck
a zone pcm
the core charge was $100 the part was $169.Make sure you have the VIN # on hand and the miles with you before you go down there.They had it shipped to my door instead of to the store which I thought was quite convenient.It came from Blue Streak Electronics.I don't know if you can order directly from them or not
Andyduck is offline
