Which line is the return line in 42rle? - Page 2 - JeepForum.com
 2Likes
post #16 of 26 Old 08-04-2010, 07:04 PM Thread Starter
sandjunkie
Originally Posted by BriansCJ View Post
Does it really matter for an external cooler that much?
Probably not but I wanted the added cooler to follow the radiator.
sandjunkie is offline
post #17 of 26 Old 08-04-2010, 07:10 PM
BriansCJ
BriansCJ's Avatar
1994 XJ Cherokee
BTW, this will solve a problem if you ever replace your rad.
Apparently, they changed the fitting sized for the trans cooler lines in 05. The relacement rads do not have the correct fitting, causing me to have to cut the cooler lines and splice in new fittings. Worked out ok, but leaks occasionally and hangs down a little more than stock.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #18 of 26 Old 09-22-2014, 06:40 PM
Texanav8r
Clearing the Confusion
So I'm going to have to throw in on this since I took this thread to be correct when I installed my external transmission filter (with option for another cooler).
I'll be posting more about that project when it's finally done and correct, but for now I had to correct this.
Looking at the transmission from the driver's side toward the passenger side, the two fluid lines are easily identified as high and low. On my 2006 LJ Rubicon, the upper line runs to the DRIVER'S side of the Cooler and the Lower line runs to the PASSENGER side (This is opposite of what Unlimite04 said).
The flow path is then:
  1. Transmission Oil Pan
  2. Transmission Oil Pump
  3. Transmission clutch circuits (see the diagrams in the manual's link below)
  4. Transmission LOWER Port
  5. Cooler Passenger side
  6. Cooler driver's side
  7. Transmission UPPER port
  8. (Repeat back to oil pan)
I now have a 'fixed' hose on the upper -> driver's side and will be adding my oil temperature sensor and filter to the other side :/
The manual doesn't lay this out very well, but it is interesting reading for anyone who is working on them.
SCRIBD - 42RLE-AUTO Transmission Manual
Also, I haven't found a good way to remove the hoses because of the stupid "Jiffy type" fittings. Here's a great video on how they work: Youtube Link
Hope this saves someone some heartache.
My Jeep Build Thread: http://bit.ly/15MGE7C
Texanav8r is offline
post #19 of 26 Old 08-27-2016, 08:25 PM
GooseNibbleBS
I hope you read this far
There's some bad info on this thread.
I can tell you with 100% certainty that if you have the 42rle 4-speed automatic offered from 2003+ that your return line, that is the line that is carrying ATF+4 from the radiator back to the transmission, is located on the DRIVERS side of the radiator. It is the shorter of the two 3/8" rubber lines on the bottom of radiator. Again, ATF goes IN the radiator on the passenger side and OUT on the drivers...end of story.
I was looking to perform a flush using the trans pump and found so much conflicting info that I finally just went with what this thread was stating. Which I know now from the huge mess of ATF on the floor of my garage, is the opposite of how the 42rle actually works.
GooseNibbleBS is offline
post #20 of 26 Old 08-27-2016, 08:53 PM
Knuckelhead
R.I.P. Knuckelhead
Knuckelhead's Avatar
GOOSENIBBLEBS'S JEEP
User Has Not Filled Out Jeep Information.
And WTFAY...
Knuckelhead is offline
post #21 of 26 Old 08-27-2016, 09:01 PM
ravenworks
ravenworks's Avatar
Never had that problem buying a OEM radiator
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #22 of 26 Old 10-04-2016, 06:15 PM
BriansCJ
BriansCJ's Avatar
1994 XJ Cherokee
This was back when OEM TJ parts were pulling a premium, and I was poor. Aftermarket was just over $100 shipped, compared to $3-$350 for a OEM.
We ended up selling that jeep about a year after anyway.
- Slow
BriansCJ is offline
post #23 of 26 Old 10-04-2016, 06:23 PM
BriansCJ
BriansCJ's Avatar
1994 XJ Cherokee
Apparently I'm not the only one to have that problem.
https://www.jeepforum.com/forum/f9/tr...oblem-1354728/
- Slow
BriansCJ is offline
post #24 of 26 Old 03-29-2017, 08:55 PM
Mictrik
This is correct for my 2004 TJ
I just flushed the 42RLE transmission on my 2004 Jeep TJ using the cooler lines. I disconnected the straight hose coming from the drivers side of the radiator. This i can also confirm is the RETURN LINE BACK to the TRANSMISSION. I disconnected the line (hose) where it attaches to the metal line, this way i used the hose from the radiator to pump old fluid into a 2.5 gallon container. i did this a few quarts at a time adding fresh fluid to the fill tube each time to replace the old fluid. I exchanged around 10 quarts when I finished adjusting the fluid level. The transmission pumped fluid while in PARK which makes it a relatively safe procedure. The total capacity is around 8.8 quarts according to the factory service manual; i removed and replaced a little extra. The factory service manual also states that the fluid level should be checked with a warm transmission while in neutral. Fluid that gets on the dipstick from the side of the fill tube can give you a false reading so look at both sides of the dip stick to see if the fluid is on both sides.
Mictrik is offline
post #25 of 26 Old 03-29-2017, 09:33 PM
ijp4fun
Use a small pick to pop out the wire clip.
ijp4fun is offline
post #26 of 26 Old 03-30-2017, 07:18 AM
grininmonkey
grininmonkey's Avatar
Yep.... I just did an Aux Cooler install and was all sorts of confused on which was outbound and inbound, for my 2004 42RLE the correct information is what you and the previous person said.
Mictrik likes this.
grininmonkey is offline
lj , wrangler , transmission , tranny , cooler , return line
Fuel Line or Return Line GrantYj88 YJ Wrangler Technical Forum 8 01-09-2010 01:05 PM
42rle cooler line fun Kinless TJ Wrangler Technical Forum 0 07-13-2009 10:19 PM
42RLE Fluid Cooling Line Burst, Why? - Any Help Please JeepsInParadise TJ Wrangler Technical Forum 9 05-26-2009 04:49 AM
hard tranny line size on a 05 with 42RLE? rockrunner TJ Wrangler Technical Forum 0 07-06-2008 05:41 PM
42rle cooler line fittings Vacant Stare TJ Wrangler Technical Forum 2 10-28-2007 09:55 AM
