LIGHTS ON REMINDER!!! Has anyone wired one of these in a TJ??? - JeepForum.com
post #1 of 14 Old 07-11-2010, 09:23 AM Thread Starter
anymanusa
I'm sure somebody has. I come from over a decade of driving three cars that had automatic lights (GM , vette, cadillac and 2500). I've already left the lights on on my '05 Rubicon a half dozen times, and even though I haven't stranded myself with a dead battery yet, I realize that I must wire in a relay warning so I don't ever do this. Does anybody have a tutorial on this?
thanks.
anymanusa is offline
post #2 of 14 Old 07-11-2010, 09:32 AM
MikalCarbine
Is your chimer not working? Mine always catches me
MikalCarbine is offline
post #3 of 14 Old 07-11-2010, 09:37 AM Thread Starter
anymanusa
So far I haven't heard one. I get a chime if I leave the parking brake on, but nothing for the lights. Maybe I should look into this. I didn't know I was 'supposed' to have a chimer.
Thanks.
post #4 of 14 Old 07-11-2010, 09:40 AM
jeepinmichguy_
jeepinmichguy_'s Avatar
check fuse 4.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #5 of 14 Old 07-11-2010, 09:41 AM
DevilDogDoc
Do your inside lites come on when you open the doors?
An ugly Jeep with some stuff.
DevilDogDoc is offline
post #6 of 14 Old 07-11-2010, 09:43 AM Thread Starter
anymanusa
^^^^ thanks for all that, I'm checking right now.
post #7 of 14 Old 07-11-2010, 09:49 AM Thread Starter
anymanusa
fuse #4 says rad/fan, and there is no fuse in place. I'm running with the doors off, and no the lights don't seem to be on because of it.
post #8 of 14 Old 07-11-2010, 09:54 AM
ajamison
ajamison's Avatar
1991 MJ Comanche
you could tap into the dash lights somewhere and wire up an LED, when the park lamps and head lights come on, so do the dash lights, i tapped into the lights that illuminate the heater controls (for a different purpose). i do not recall which color wire i used, but i do remember that it was pretty simple to figure out
Jamison
ajamison is offline
post #9 of 14 Old 07-11-2010, 09:59 AM
Sundowner
Sundowner's Avatar
You need to look at the fuse behind the glove box, not under the hood...
Sundowner is offline
post #10 of 14 Old 07-11-2010, 10:06 AM Thread Starter
anymanusa
^thanks, I'm doing that now. I'm new to this vehicle (3 days now) so I didn't know this yet.
post #11 of 14 Old 07-11-2010, 10:12 AM Thread Starter
anymanusa
thanks so much. that did the trick. Someone had removed it completely. If you get a chance, please tell me what amperage of a fuse is supposed to go there. Now the interior lights come on when the doors are open and the reminder beeps too. I just need to know how big a fuse to put in now.
thanks again.
post #12 of 14 Old 07-11-2010, 10:21 AM
rchase559
rchase559's Avatar
Its a 10 amp fuse.
rchase559 is offline
post #13 of 14 Old 07-11-2010, 10:45 AM
monkeee2002
thanks again.
Fuse #4 tells your Jeep that the door is open / closed. When you take off the doors, most people take out that fuse. (It also keeps the dome light from staying on).
I'm in the same boat as you, I've left my headlights on countless times.
I suppose I should look for a DRL mod...
Congrat's on the new Jeep!
The skinny pedal on the right is my friend. the gas gauge is not.
monkeee2002 is offline
post #14 of 14 Old 07-11-2010, 11:00 AM
S10Eater
S10Eater's Avatar
if i leave the lights on in my tj, when i open the door i get a chime and the highbeam indicator flashes.
1987 350 JEEP COMANCHE
Licence plate: FSTJEEP
2001 TJ SE, 31" KM2s, cragar d styles
JEEP: If i wanted a Hummer, I would have asked your sister
S10Eater is offline
lights , reminder , noise , write-up , tj , wrangler
fog lights wired in but dont work klincker TJ Wrangler Technical Forum 4 12-30-2008 12:39 PM
Wired in Aux lights, now voltage is high. Raztt TJ Wrangler Technical Forum 12 09-02-2008 09:58 PM
LIGHTS-On REMINDER WITH DOORS OFF??? JK322BC JK Wrangler Technical Forum 2 08-19-2008 12:35 PM
Need help.... wired lights and no power or lights?? Q-01 TJ Wrangler Technical Forum 6 01-27-2008 06:49 PM
x's pre-wired for fog lights? dmblax23 TJ Wrangler Technical Forum 1 08-25-2003 09:29 PM
