JeepForum.com (https://www.jeepforum.com/forum/)
-   TJ Wrangler Technical Forum (https://www.jeepforum.com/forum/f9/)
-   -   Lift and gears (https://www.jeepforum.com/forum/f9/lift-gears-3564690/)
Denbowcj7 01-03-2016 07:21 PM
Originally Posted by rda616
The Aussie locker is fine. Many of us have had them for years and like them. You already have a nice long spring with the RC 2.5". You will benefit from quality shocks. The RC shocks are awful. If you don't have front disconnects, or better an antirock you aren't using the suspension travel the 2.5" kit you have is capable. You don't need more suspension lift for a 33" tire. You need to add a 1.25" body lift and a 1" motor mount lift. This will, or should allow you to remove any transfer case drop that you may already have. With the 1.25" BL and your 2.5"SL you should require no more bumpstop extension than what you have now requires. You need to understand more lift doesn't mean a more capable suspension, but it does require many other upgrades when you hit that 3.5"-4" mark.
if I don't have a tcase drop now, then I should still go this route? I do have disconnects, and I'm picking up that locker up tomorrow.
365Jeep 01-03-2016 07:27 PM
Originally Posted by rda616 (Post 33431938)
You already have a nice long spring with the RC 2.5"...You will benefit from quality shocks...If you don't have front disconnects, or better an antirock you aren't using the suspension travel the 2.5" kit you have is capable...You need to add a 1.25" body lift and a 1" motor mount lift. This will, or should allow you to remove any transfer case drop that you may already have. With the 1.25" BL and your 2.5"SL you should require no more bumpstop extension than what you have now requires.
I did edit rda616's post a bit in the quote above, but this is all really good advice. I forgot the OP mentioned the RC 2.5" lift. The BL and MML with the 2.5 should be plenty for 33's. Spend the remainder of your money on the best shocks you can afford (and the right length), and I think you'll be set. The Aussie may be fine, but I would still invest in suspension as a priority.
365Jeep 01-03-2016 07:33 PM
Yes. The MML will help with driveline angles.
Denbowcj7 01-03-2016 08:12 PM
so just get a better 2.5 in lift along with the BL and MML?
rda616 01-03-2016 08:43 PM
You don't need new springs unless you are adding a bunch of weight, but would benefit from quality shocks. You should buy shocks by extended and collapsed length and not by advertised lift size.
365Jeep 01-03-2016 08:46 PM
Maybe we have overlooked a few things here.
There are a variety of Rough Country lifts available. Are you still using your stock control arms, or is your lift just longer springs and shocks?
This is the priority I would set. If you have any of the following items, don't replace them. Build on the things you already have.
  1. Good Springs
  2. Great shocks
  3. Currie Antirock or sway bar disconnects
  4. Flexy and adjustable control arms
  5. Motor Mount Lift & Body Lift to get the height you're looking for. (if you're looking for height)
  6. Adjustable track bars
365Jeep 01-03-2016 08:54 PM
This! Meaning you will want to remove your shocks and cycle your suspension to see full compression and extended lengths. The adjustable Ranchos are well regarded, come in a variety of lengths, and are reasonably priced. There are better shocks, but Rancho gives you a big bang for the buck, IMHO.
Denbowcj7 01-03-2016 09:05 PM
Maybe we have overlooked a few things here. There are a variety of Rough Country lifts available. Are you still using your stock control arms, or is your lift just longer springs and shocks? This is the priority I would set. If you have any of the following items, don't replace them. Build on the things you already have.[*]Good Springs[*]Great shocks[*]Currie Antirock or sway bar disconnects[*]Flexy and adjustable control arms[*]Adjustable track bars
yea I need some control arms and I planned on get the track bar soon. What brand should I go on the control arms? RC alright?
365Jeep 01-03-2016 09:16 PM
Again, depending on your budget...
Aluminum Savvy
Standard Currie
Metalcloak
I don't see that RC sells control arms, but I know several others do. Others may want to chime in here.
lander2312 01-03-2016 09:44 PM
Yes rough country sells an adjustable control arm. They have come a long way with quality in last 2 years. With that said...and I hate to hi jack this thread but could others smarter than me explain why one would spend the extra money for adjustable upper control arms?
Denbowcj7 01-03-2016 09:54 PM
Again, depending on your budget... Aluminum Savvy Standard Currie Metalcloak I don't see that RC sells control arms, but I know several others do. Others may want to chime in here.
the whole set? Front and rear, upper and lower?
365Jeep 01-03-2016 10:24 PM
That's up to you. The main advantage is articulation and flexibility. The next is adjustability.
365Jeep 01-03-2016 10:29 PM
Originally Posted by lander2312 (Post 33436154)
...could others smarter than me explain why one would spend the extra money for adjustable upper control arms?
If you have to choose adjustable, it's more important to choose the uppers. Adjustable rear uppers adjust pinion angle to compensate for lift either for a standard driveshaft or double cardan style. Adjustable front uppers adjust for driveshaft angle and also caster angle. The lower arms shouldn't need to be adjusted much from stock length in most cases.
Denbowcj7 01-03-2016 10:44 PM
I'm probably gonna go with the RC brand, mainly because I get a discount through them. 699.95 for the whole set
Knuckelhead 01-03-2016 10:53 PM
Both upper and lower axle control arms come into play when changing chassie lift and drivetrain. The front upper control arms may not need to be addressed in most cases with 4" and lower lifts.
Keeping the wheels centered in the wheel wells is important for clearance when articulating the suspension... HTH
The time now is 05:15 AM.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
