lets play name that part - JeepForum.com
post #1 of 25 Old 07-31-2013, 10:53 AM Thread Starter
dodgeramvt
I apologize up front for this ridiculous question but what in the hell did i just break? and by break i mean the bolt up top broke but while it's off i'm going to replace the rubbers. it's 11inches long (the part that is)
dodgeramvt is offline
post #2 of 25 Old 07-31-2013, 11:08 AM
kloppk
kloppk's Avatar
sway bar link
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #3 of 25 Old 07-31-2013, 11:10 AM
angelo2975
angelo2975's Avatar
Stablizer bar link/Sway bar link
2002 FSM PDF version
angelo2975 is offline
post #4 of 25 Old 07-31-2013, 11:35 AM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
Time for upgrade.
RnEmOvr is offline
post #5 of 25 Old 07-31-2013, 12:04 PM Thread Starter
dodgeramvt
ok thank you for that, what would the recommendations be for an upgrade on these? there around 11 inches in length. also this pic i just provided i noticed that there is about an inch and a half or so of play left to right which was causing the passenger side link to rub/knock against the frame you can see the play right on the bar near the bushings. i assume if i replace the bushings that should take care of this? i'm getting a slight wobble in the wheel around 40mph i assume it's coming from this mess of worn out parts.
post #6 of 25 Old 07-31-2013, 12:05 PM Thread Starter
dodgeramvt
these are the other photos of whats happening.
post #7 of 25 Old 07-31-2013, 12:23 PM
RnEmOvr
RnEmOvr's Avatar
Depends on usage and budget. Many people will scream anti-rock. If budget allows and you wheel the Jeep then I agree. If street queen with low budget get some JKS extended links. As for the sideways shifting, no big deal. A simple pipe or hose clamp on the inside will keep that from happening. The bushings on the bar are fine.
RnEmOvr is offline
post #8 of 25 Old 07-31-2013, 12:52 PM Thread Starter
dodgeramvt
Could the links have been on wrong to cause such a shift in the bar? The drivers side was perfect, no frame kissing at all. It was all on the passengerside. It seems there was a ton of slop on that side? The links have a little bend in them which i assume go outward to open that bar up and push it away from the frame. (Bear with me this is my first jeep and im hellbent in fixing this thing and learning as i go, i really appreciate the help!!)
post #9 of 25 Old 07-31-2013, 02:10 PM
RnEmOvr
RnEmOvr's Avatar
That is a very well known issue with the stock bar. It just happens. Nothing is wrong or anythign like that.
RnEmOvr is offline
post #10 of 25 Old 07-31-2013, 02:13 PM
Necko2529
Necko2529's Avatar
The reason the bar is shifting side to side is due to tire coming in contact with it when turning...
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #11 of 25 Old 07-31-2013, 02:29 PM Thread Starter
dodgeramvt
Well i can say without a doubt i have zero tire rub now. Maybe when the po had it it use to before the lift but i have a ton of space when the wheel is hard over. I am going ti try the hose clamp idea. That seems like a logical fix to stop it from moving. What about bump stops? Anything that could mount to the frame to keep it from rubbing?
post #12 of 25 Old 07-31-2013, 02:32 PM
Necko2529
Necko2529's Avatar
What's your backspacing on your rims? Are they stock or aftermarket? Do you have spacers?
post #13 of 25 Old 07-31-2013, 03:09 PM Thread Starter
dodgeramvt
they are aftermarket rims (i do not know what brand) no spacers. i didn't see any rub on the swaybar at all. i found this tho, http://www.4x4xplor.com/swaybar-fix.html seems like an easy fix. maybe this will stop the damn clunk i get every now and then from the front end.
post #14 of 25 Old 07-31-2013, 05:36 PM
Knuckelhead
R.I.P. Knuckelhead
Knuckelhead's Avatar
Many have used that to fix your issue.
Check at any bearing supply warehouse near you to find them, they're called double split shaft collars...
Knuckelhead is offline
post #15 of 25 Old 07-31-2013, 06:18 PM
tjsean0308
tjsean0308's Avatar
couldn't help but notice you have a decent amount of oil on the trac bar Tie rod end at the frame. I suspect you have something else causing your shimmy that is in turn creating the sway bar shift and thus the clunk. Time to do a dry steering test.
tjsean0308 is offline
