Leaking radiator? - JeepForum.com
post #1 of 5 Old 11-14-2009, 03:50 PM Thread Starter
mightydog78
mightydog78's Avatar
Leaking radiator?
After just driving my jeep I came back out to look at it and notcied a huge puddle of what smelled like nothing so I assumed it was water/andtifreeze. My coolant resivior was empty.
Also, The whole underside of my jeep was wet, on the transfer case skid, oil pan, and tranny. Could this spray be from the radiator leaking? I think it could be time for a new radiator if this is my problem
If anyone could diagnosis this problem it would be appreciated.
2013 JKU Sahara
Charlotte, NC / Southport, NC
Mechanical Engineer
mightydog78 is offline
post #2 of 5 Old 11-14-2009, 04:49 PM
dogbluedrummer
Trust me....
dogbluedrummer's Avatar
Check the weep hole on your water pump. I bet that's the cause. Option 2 is probably the radiator.
Patriot Blue 2001 TJ
Everything I need to fix on the heep: ABS indicator, speed 4 on the blower fan, torn softop over driver's head, both seat release/tilt cables, missing center cap on spare, broken under hood light, wire up the CB, wiring problem with the reverse lights, broken bottle jack, leaky front and rear pinion seals, loose trackbar relocation bracket, torn drivers seat on the side, broken center console lock, lost nuts for door hinges, squeaking centering ball, loose parking brake cable, oil change and rotate the tires.
My build thread
dogbluedrummer is offline
post #3 of 5 Old 11-14-2009, 07:18 PM Thread Starter
mightydog78
weep hole?
Im a noob and dont know where thats at
2013 JKU Sahara
Mechanical Engineer
post #4 of 5 Old 11-14-2009, 07:40 PM
kdub0013
I had this same problem with some overheating. Needed a new radiator and thermostat...
kdub0013 is offline
post #5 of 5 Old 11-15-2009, 12:03 AM Thread Starter
mightydog78
did you get the OEM replacement radiator or go with a aftermarket one?
2013 JKU Sahara
Mechanical Engineer
new radiator cap leaking gene97sport TJ Wrangler Technical Forum 0 04-29-2009 04:56 PM
Leaking radiator?? Mickeymouse YJ Wrangler Technical Forum 2 05-13-2007 01:41 PM
Leaking Radiator ccbiggz TJ Wrangler Technical Forum 21 11-08-2006 04:01 PM
radiator leaking jasper TJ Wrangler Technical Forum 12 12-06-2005 10:01 PM
new radiator is in and leaking!!! ohhpe YJ Wrangler Technical Forum 10 08-29-2005 07:13 PM
