Page 1 of 2 | 1 | 2 |
LinkBack | Thread Tools |
keyless entry on a TJ anyone do it?
i was surfing quadratec and came across this keyless entry kit. Anyone do this conversion? It would be nice for the lazy factor and the fact that my doors and ignition don't share the same key or won't once i replace the door
Electric-Life 2 Door Power Door Lock and Keyless Entry Kit
$124.99
Quadratec Part No: 55016.120
Convert your old manual door locks to full power remote. Our combination power door lock and keyless entry system will convert your old manual locks to full power.
Limited Lifetime Warranty.
Installation Notes
Install Time: 1-2 Hours
Need tools? Click here
Fits these Vehicles
Universal Fit - This part will fit most vehicles. Some universal fit products require that you select a specific size or style, based on the actual features on your Jeep or truck.
Product Details
Comes with (2) 4-button transmitters that can activate your locks from 100 feet away.
$124.99
Installation Notes
Fits these Vehicles
Product Details
2016 Rubicon Hard Rock JKU - ready for the mods
98 Sahara
2005 Rubicon
Sponsored Links | |||
I've seen acuaters installed. They worked good very expensive though. They were used with an alarm. Unless you have a hard top I would not even consider it though.
keyless entry kit .....remove doors?
o6 LJ see profile...
Guest
haha Yhea i have my actuators waiting to be put in. I bought them from Bestbuy for like 5 bucks a piece (discount) but normally they still only sell for 30 ish. Pretty much everything you need except the keyless transmitter, which if ur planning on adding a alarm like myself you will get separately. However im sure the quadratec kit works just as well and has all the odds and ends where i might have to dig around the garage alittle bit more for everything. If i can find the write up i used for reference i will post it.
I did something like this for around $30.
http://cgi.ebay.com/KEYLESS-ENTRY-2-...QQcmdZViewItem
Works flawlessly.
Something else you might be interested in...
https://www.jeepforum.com/forum/showt...agnum+Shooters
Works flawlessly.
dllb,
did you just put connectors at the doors so you can take them on and off?
98 Sahara
2005 Rubicon
yup i have keyless entry with alarm.....we added just keyless entry to my dads for about 30 dollars
Originally Posted by Bot
dllb,
yep, also makes for a clean install, no wires running to the doors. The only drawback is the doors have to be closed before you can lock them with the remote.
but seriously...
I would only put a keyless entry if i was going to add an alarm as well. If you are like me and value the items inside of your jeep, it is worth it to get an alarm and put the door lock actuators on. I have a soft top, so i am more prone to the theft thing, thats why i have remote door locks and an alarm....
Wizard of Brakes
keyless entry kit
I am Savvy
blackmagicbrakes.com
Guest
Originally Posted by Jeepguy1977
lol
I was thinking that when I read the title
I didn't even know the doors came with locks!
Joe
2005 Solar Yellow X
2" Skyjacker BB - 31X10.5\15 Cooper STT
I bought my keyless entry mechanism from 4wd hardware. It wasn't cheap at $300 but it does the job flawlessly. There's only two pins to connect with the doors and that's it, you are ready to go.
2001 XJ Sport 4.5" LA
1999 TJ 2.5L 5spd 2" lift
I've never even locked my Jeep! Not even sure that the doors are keyed the same as the ignition.
"There's only two things in life, but I forget what they are." -John Hiatt
Previous Thread
Next Thread
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Similar Threads | ||||
Thread | Thread Starter | Jeep Forums | Replies | Last Post |
Keyless Entry Pad - For remote keyless entry systems | ericg | JK Wrangler Technical Forum | 16 | 06-04-2009 04:28 PM |
Keyless entry....on another JK!! | roxy | JK Wrangler Technical Forum | 9 | 05-03-2009 10:56 AM |
keyless entry | bswish247 | JK Wrangler Technical Forum | 4 | 05-18-2008 11:02 PM |
keyless entry | joebruni | TJ Wrangler Technical Forum | 10 | 05-19-2006 12:22 PM |
Keyless Entry | JT03Rubicon | TJ Wrangler Technical Forum | 37 | 02-23-2003 09:16 PM |
Posting Rules | |
