jks bl,mml,discos Anything i should know - JeepForum.com
post #1 of 13 Old 11-07-2009, 03:44 PM Thread Starter
APEDZ04LJ
APEDZ04LJ's Avatar
Hopefully this upcoming weekend i will be installing a jks, mml, bl, and discos, and was wondering if there is anything jks doesent tell you about installing these that i should know about before i start?
APEDZ04LJ is offline
post #2 of 13 Old 11-07-2009, 03:50 PM
Imped
Imped's Avatar
Nope. All straight forward. Due to the passenger side lean, you'll find that the passenger side link probably needs to be slightly shorter. This is normal. You want the links to be able to slide on and off....no forcing should be needed.
OlllllllO
IndyORV
Imped is offline
post #3 of 13 Old 11-07-2009, 03:54 PM Thread Starter
APEDZ04LJ
APEDZ04LJ's Avatar
i did i serach and couldnt find anything about instaling the mml, yet i hear people having problems with this, is there a write up about it?
post #4 of 13 Old 11-07-2009, 03:58 PM
Imped
Imped's Avatar
Get a friend to help for the MML
YouTube - ROKMEN - Body Lift, Motor Mount Lift Installation -Part 2
OlllllllO
IndyORV
Imped is offline
post #5 of 13 Old 11-07-2009, 04:48 PM
dogbluedrummer
Trust me....
dogbluedrummer's Avatar
BL = super easy.
Discos = easy, but you need a drill and tap (forgot size).
MML = sucks bad, get a friend, get a floor jack, don't be a puss when jacking up the engine, have at least 12 beers on hand.
Patriot Blue 2001 TJ
Everything I need to fix on the heep: ABS indicator, speed 4 on the blower fan, torn softop over driver's head, both seat release/tilt cables, missing center cap on spare, broken under hood light, wire up the CB, wiring problem with the reverse lights, broken bottle jack, leaky front and rear pinion seals, loose trackbar relocation bracket, torn drivers seat on the side, broken center console lock, lost nuts for door hinges, squeaking centering ball, loose parking brake cable, oil change and rotate the tires.
My build thread
dogbluedrummer is offline
post #6 of 13 Old 11-07-2009, 06:03 PM Thread Starter
APEDZ04LJ
APEDZ04LJ's Avatar
what do you need to drill for the discos?
post #7 of 13 Old 11-07-2009, 06:25 PM
RogueSpear2023
The MML was almost as easy as the BL just follow the Rokmen video and you will be fine, I did by myself with no problems. Other than I did cut my hand when I tried to get my gorilla hands up to grab the motor mount, I now have a permanent scare, the jeep was just trying to tell me that I am hers I guess.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #8 of 13 Old 11-07-2009, 06:30 PM Thread Starter
APEDZ04LJ
APEDZ04LJ's Avatar
Hey, you have to get battle scars somehow
post #9 of 13 Old 11-07-2009, 09:25 PM
wntrcmpr
You need a drill and tap to install the storage pins
wntrcmpr is offline
post #10 of 13 Old 11-07-2009, 10:16 PM
TJ-xtreme
Body lift = Easy
MML = Easy (make sure you only do one side at a time.)
Disco's = Easy (you don't have to do the storage pins but they are handy to have...)
2001 TJ Sport w/ D44, 2.5" Susp. lift,1" BL w/ MML, 35x12.50 BFG KM2's on 15x8 Soft 8's, Smittybilt XRC Front Bumper and Rocker Guards, S/B SRC Rear Bumper, Xenon 4" Flat Flares, JKS Disconnects, 48" Hi-Lift Jack, OBA System, Optima Blue Top, Hella Lighting. More on the way... ;}
JEEP= Just+Empty+Every+Pocket.....
EAT-SLEEP-JEEP OlllllllO
TJ-xtreme is offline
post #11 of 13 Old 11-07-2009, 10:29 PM
TJDaveX
TJDaveX's Avatar
All of the above plus.......
MML: I could not get the long bolt to slide out on the driver's side due to the AC pump. I unbolted the whole mount from the motor, then it was a piece of cake.
JKS instructions say that you do not have to use the included TC shifter bracket if you install both the BL and MML. With my Jeep, I needed it. Even after adjusting the slide thingy, it would still pop out of 4lo when off road. Others have not had this problem. Must be an individual Jeep thing.
TJDaveX is offline
post #12 of 13 Old 11-07-2009, 10:31 PM
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
Advice, the MML install blows.
Prepare for a long weekend with lots of bloody knuckles and lots of frustration.
Oh, and dont do it in the rain. That doesnt help the situation
2016 TJ of the Year
Founder,
EugeneTheTJ is offline
post #13 of 13 Old 11-07-2009, 10:49 PM
DH19922010
Same for my jeep. Stupid jeeps all have to be different from each other! To the OP, body lift is super easy to do, mml a little difficult but not too bad, and i've never done disconnects but they're on my to do list! This poor high school student needs a job again... once my hand heals up
DH19922010 is offline
JKS Quick Discos vs JKS Quicker Discos Houndmaster1 TJ Wrangler Technical Forum 9 05-22-2009 06:07 PM
Which JKS discos should I buy? TJJP77 TJ Wrangler Technical Forum 7 05-10-2007 08:28 PM
RE Gen 2 Discos BAD / JKS Quicker Discos GOOD thejafe TJ Wrangler Technical Forum 14 05-02-2007 04:43 AM
Anyone seen these new discos? Deezul TJ Wrangler Technical Forum 11 03-20-2006 02:25 PM
RE gen II discos or JKS discos jeepfunatic TJ Wrangler Technical Forum 12 10-08-2005 09:59 AM
