Jeep Wrangler Vapor Canister Hose - JeepForum.com
post #1 of 5 Old 09-15-2012, 02:45 PM Thread Starter
Tjosh97
I have a 1997 TJ SE and looking for pics or a diagram of the routing of hoses for the vapor canister? I took my jeep to get the fender repair about 4-5 months ago and the check engine light P0441 keeps coming on. It could be a old gas cap, but I think they might have taken off my hoses or broke something under the hood. So seeing if anyone can get some shots of the vapor canister on the driver side under the hood. I see three plugs-in for hoses on the canister, and only tow of mine are being used. Will post pic when I can thanks.
Beep Beep, who got da keys to the JEEP???
Red Jeep Club #556 - "DA 4-$LANGER"
1997 Flame Red TJ 4-Banger (2.5L) 4.0 TB 62mm Bored w/ Spacer -- 31x10.50 D. Cepek "Crushers" -- 15" Black Rock Crawlers -- AEM DryFlow -- Dynomax Super Turbo Cat-Back -- EBC Brake System -- Rough Country 2.5" Lift w/ Discos -- RC Adj Track Bars -- Currie HD Steering -- Rugged Ridge Diff Covers - DDM 6000K HID
Tjosh97 is offline
post #2 of 5 Old 09-15-2012, 04:16 PM
Jonny Jeep
Jonny Jeep's Avatar
I think there should be a label on the hood that shows the connections for the emissions canister along with the vacuum diagram schematics.
Jonny Jeep is offline
post #3 of 5 Old 09-15-2012, 04:21 PM Thread Starter
Tjosh97
I give it a look
Tjosh97 is offline
post #4 of 5 Old 09-15-2012, 06:18 PM
silver97tj
silver97tj's Avatar
hi all
maybe this will help......
2012-09-15_18-01-06_824.jpg   2012-09-15_18-01-27_759.jpg   2012-09-15_18-01-36_307.jpg   2012-09-15_18-01-44_830.jpg   SP32-20120915-180642.jpg
1998 Blue TJ, 4 Cyl., Auto (30rh), Hardtop with installed Sunroof, mostly stock.
31x10.5x15 Mud Tires, TJ Rubicon springs, Mopar Deep Trans Pan and Cooler
Army Vet and proud of it! Have you served your country?
Support our Troops!! Thank You!!!
silver97tj is offline
post #5 of 5 Old 06-06-2016, 07:53 AM
JeepJeepGo
Resolved???
Did you ever get this resolved? I have the same issue with recent work, now check engine light with P0441 code and only two hoses connected to vacuum canister.
JeepJeepGo is offline
charcoal canister/vapor canister took a dump need help AmmitOsiris YJ Wrangler Technical Forum 5 12-29-2011 08:34 PM
Vapor Canister qlfarm YJ Wrangler Technical Forum 5 12-19-2011 08:25 AM
New Vapor Canister? MJDriver YJ Wrangler Technical Forum 7 02-08-2010 07:36 PM
Where can I get a new vapor canister? Matt_vs_YJ YJ Wrangler Technical Forum 12 04-03-2008 11:24 PM
vapor canister t_rexx70 YJ Wrangler Technical Forum 3 11-01-2006 02:52 PM
