Jeep wranger door problems - Page 2 - JeepForum.com
 9Likes
post #16 of 19 Old 09-05-2017, 08:34 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by tjlemay View Post
I have stock fenders. Did not loosen the hinge bolts I can try that and reposition them I guess. And I take them off the same way that I always do. I just lift them up and out, don't have the bottom nut that goes on the pins, never have.
Sent from my SAMSUNG-SM-G920A using Tapatalk
The max adjustment forward and back for the windshield frame is controlled by the pan head Torx with the black plastic washer under the head in the windshield hinge. If you loosen that and loosen the bolts that are at the front of the spreader, that will show you how far you can push the top of the windshield forward.
I've seen the misalignment issue you have but only with aftermarket fenders and after someone jumper their rig and nosed it hard. The aftermarket fenders tagged a boulder and suffered a small scratch. The door opening got pushed back far enough that the back of the door overlapped the opening.
olysteve likes this.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #17 of 19 Old 09-05-2017, 08:39 PM Thread Starter
tjlemay
I tried that unfortunately. Loosened the windshield bolt with the plastic washer, as well as the roll cage to windshield bolts, and the roll cage torq bolt, no luck. I did three wheel it the other day between a rock and a hard place. That's the only thing I can think of.
tjlemay is offline
post #18 of 19 Old 09-06-2017, 05:57 AM
NotURMailman
NotURMailman's Avatar
You really should see how the door fits in the opening. Fold the windshield all of the way forward onto the hood and see how the door shuts then.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #19 of 19 Old 09-06-2017, 10:13 AM Thread Starter
tjlemay
Ok I will try that out when it stops raining. Thank you!
tjlemay is offline
