Jeep TJ Heat Coming In - JeepForum.com
post #1 of 9 Old 06-28-2020, 12:29 PM Thread Starter
golphnut01
I bought a 2000 Jeep TJ about one year ago. First time owner and have driven it mainly on weekends. It has probably about four inches of lift. This jeep seems to get a lot of heat in from underneath. It comes in around the emergency break handle, four wheel drive shifter as well as around the brake and gas pedal area. Is that normal? Is there a fix? Thanks in advance.
golphnut01 is offline
post #2 of 9 Old 06-29-2020, 08:24 AM
EricD
shift boot pan
Does the 2000 have this?
I know when I replaced mine, it was a drastic improvement.
EricD is offline
post #3 of 9 Old 06-30-2020, 06:03 AM
EricD
Now that I think about it, I don't think that style inner boot was used in 2000. But there is probably a hole in whatever inner shift boot you do have.
EricD is offline
post #4 of 9 Old 06-30-2020, 10:16 AM
RFH_98TJ
I would agree that is where the problem usually is - it was for me. They cost about $20 shipped. My '98 is smaller than that, but does the same thing. A small hole or rip in it can let in a lot of hot air right off the engine and exhaust manifold. When I had my console out, I added SS tape around the cup holder's underside and added spray foam around them too to fill the cavity in. I put some SS tape on the tunnel too. Drinks stay cold a LOT longer now.
RFH_98TJ is offline
post #5 of 9 Old 07-01-2020, 09:00 AM Thread Starter
golphnut01
I am off next week and planning to take the console out and see what is there.
post #6 of 9 Old 07-01-2020, 11:38 PM
mukluk
mukluk's Avatar
In addition to checking for a torn transmission shifter boot, check to see if you have heat coming from the HVAC foot vent when it isn't selected. The foot door actuator or door linkage may be faulty. If you don't have the factory carpet installed, you may also be getting a lot of heat transferred through the floor from the exhaust and drivetrain which is normal, the stock carpet has thick heat insulation on the underside to shield against this.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #7 of 9 Old 07-03-2020, 08:41 AM Thread Starter
golphnut01
It has carpet. I will check that duct work also cause I get heat down around my legs also. Thanks for all of the comments guys. They really give me great information on what to look for.
post #8 of 9 Old 07-07-2020, 11:52 AM
SeanCucf
SeanCucf's Avatar
Here's the "inner shifter boot" I put in my 2002. Maybe yours is the same
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
SeanCucf is offline
post #9 of 9 Old 07-07-2020, 04:40 PM
dln1962
Junior Member
That's exactly the one my 2000 needed. It needed the upper boot too, getting them replaced made a huge difference in both heat and noise.
dln1962 is offline
