Jeep TJ DD Lift Kit for 33's - Page 2 - JeepForum.com
 5Likes
post #16 of 23 Old 11-14-2017, 05:21 AM
BMorrNH
OME 2.5" HD clears my 33's, been like this for years, drives better than stock. Just picked up a 1" body lift and it will go on as soon as I can figure out how to raise my src roof rack an inch in the back!
BMorrNH is offline
post #17 of 23 Old 11-14-2017, 09:15 AM
rficken42
rficken42's Avatar
i have 2.5 Old Man Emu springs went with the v8 zj ome springs for the weight of the winch. after market upper & lower control arms. rough country track bars but they are junk. looking at metal cloak track bars.
rbaucom7266 likes this.
99TJ 5.2V8 ax15 2.5lift dana30/44 Lockers 410s 35s AtlasII bellyup skid & winch
rficken42 is offline
post #18 of 23 Old 11-14-2017, 07:17 PM
bigfoot80
I was looking at the 4.25 combo lift. but as it is I worried about the driveline vibes/ with my state lift laws are changing. The 33's fit I do get some rub on the passenger side swaybar at full left turn, due to still rolling on the stock trackbar. But I just ordered a metalcloak bar. I also installed a MML which helped with some driveline vibes. My current trajectory I am thinking long term a tummy tuck so at that time I will go with a body lift.
honestly I havent flexed it out with the sway bars disconnected, but it does fireroads and dirt roads just fine along with pavement pounding.
05 TJ sport
bigfoot80 is offline
post #19 of 23 Old 11-22-2017, 07:34 PM
etsubchief
I did a 3" zone. Running 33's and have no issues. This is my DD and I do some weekend fun. I am happy with it.
06' Silver Unlimited, 3" suspension lift, 33 Discoverer STT's, Black Rock Wheels
etsubchief is offline
post #20 of 23 Old 11-22-2017, 08:25 PM
Freeagent27
Originally Posted by Kiwi_TJ
Hi There, I have a BDS 2" kit on my TJ, I just purchased the springs from them, then spend a bit more cash on Bilstein shocks. This set up has been on my TJ for over 8 years and is as solid as the day it was put in. I got about 2.5" from the lift, due to being only a soft top, so I think you will get a little more than advertised with these guys. The BDS shocks get a good rep as well. So if you were wanting something good for a reasonable price that I would recommend that you take the one on the link below into consideration. http://bds-suspension.com/product?ma...5&yr=2003-2006
You are running 33s on the 2" BDS? Assuming you got the 2" considering you mentioned getting 2.5"? I am curious as I just had the BDS 2" installed a few weeks ago with the Fox 2.0 shocks. No body lift or Mml.
"My thoughts on yoga pants? Depends who I'm walking behind".
Freeagent27 is offline
post #21 of 23 Old 11-22-2017, 09:28 PM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
2.5" of lift with 33s. Not a lot of clearance.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4.25" combo lift/Rancho 9000XL shocks/5.13 gears-35" MTZs/BM brakes
99' XJ / 5" BDS lift/ 33" DC extreme country MTs. Jeep #18
TheBoogieman is offline
post #22 of 23 Old 11-23-2017, 08:56 AM
Freeagent27
So for a DD pounding pavement every day you could probably get away with running 33s on 2.5" with no bl or mml without any rubbing or clearance issues? More than likely though if taken on a trail you would have major rubbing issues without a minimum of high clearance fenders? I know what you COULD do and SHOULD do is what creates or reduces problems down the road. I do like the look though, but if i understand functionally it may be an issue?
post #23 of 23 Old 11-23-2017, 09:26 AM
TheBoogieman
Distubed Jeepaholic
My brother ran 33s with a 2.25" BB for about a year on the street with no issues. He soon added a BL and then went to a 4" SL and BL, then 35s. It never ends.
lift , tj , wrangler , zone
