Jeep doors frozen...can't get in!?!? - JeepForum.com
post #1 of 31 Old 12-22-2009, 07:16 AM Thread Starter
jamesbernatchez
So I power washed all the salt off my TJ last night and now this morning the door locks are frozen. The passenger side is frozen that I can't even turn the key, so I will wait to after work to take a torch/blow dryer to it and then lube it with silicone.
The issue is with the driver door. The key was able to be turned and then the actual door handle was stuck. I pulled hard enough that it came unstuck and opened the door, but now the outside and inside handle to not actuate the mechanism. I shut the door and can't open it anymore. Is there a cable or something that could have snapped.
I can put my key in the hole and turn it to lock/unlock but it actually doesn't do anything and I can't open the door. What the hell!!! Any ideas how to get this door open. I want to take the doors off, take off the door cards and lube everything up. I need to drive this to work tomorrow, but can't if I can't get in.
I will now no longer powerwash in the cold
jamesbernatchez is offline
post #2 of 31 Old 12-22-2009, 07:27 AM
AlexGeorgakis
AlexGeorgakis's Avatar
Can't help you on fixing the problem, but next time your lock freezes, just heat your key up with a lighter and insert it in the lock. You'll be able to unlock in a few seconds. Don't do it with electronic keys (which doesn't apply to Wranglers).
AlexGeorgakis is offline
post #3 of 31 Old 12-22-2009, 07:34 AM Thread Starter
jamesbernatchez
I was thinking about heating the key, but was in a rush and wasn't thinking clearly. I'm wondering, anybody know if I can try the coat hanger in between the window/door to get the door to open? Not sure what the insides look like so not sure if this is valid way to do this.
post #4 of 31 Old 12-22-2009, 07:34 AM
stuntjumper
stuntjumper's Avatar
Next time you wash your jeep in the cold just take the doors off to hang dry 'em. Benefit of the jeep.
stuntjumper is offline
post #5 of 31 Old 12-22-2009, 07:49 AM
timberwolf0122
timberwolf0122's Avatar
2020 J-Series Truck
Go to the back of the jeep, open the trunk/un-zip the door and crawl in and open the door from the inside. If that doesn't work start the engine and crank the heater up to max and set the air to re-cycle that should warm things up.
Atheist Jeep Club Member #2
Doctor Who has died 13 times, is on his 14th regeneration and has a time machine, beat that Jesus.
timberwolf0122 is offline
post #6 of 31 Old 12-22-2009, 07:55 AM Thread Starter
jamesbernatchez
I'll try that for the passenger door, but won't that not work considering I think something has snapped or came undone in the driver door. When I had the driver door open the one time, I tried the inside latch to see if it worked and it didn't. My only option from what I can see is if I can jimmy the door latch open with a slim jim type item.
post #7 of 31 Old 12-22-2009, 08:00 AM
stuntjumper
I don't know about the Jeep, but on most doors the handle is connected to a rigid metal rod that connects to the latch. That metal rod may have broken or popped out. You can get a door clip removal tool for about $5 or less to remove the panel. It's generally pretty easy.
post #8 of 31 Old 12-22-2009, 08:10 AM Thread Starter
jamesbernatchez
That's what I'm thinking. The issue I believe is that I can't remove the door panel with the door shut can I? If I could I would just climb in and do it from the inside.
post #9 of 31 Old 12-22-2009, 08:28 AM
DBLJ
DBLJ's Avatar
You can but its a pita with the seat in the way. The metal rod probably popped off.
Buy my transmission cooler. Derale TJ cooler.
DBLJ is offline
post #10 of 31 Old 12-22-2009, 08:46 AM
stuntjumper
You should be able to enough to get a hand in there and get the door open. Take as many clips and screws off the panel as possible and bend it away from the door to get your hand in there. Feel or look around for a metal rod and give it a pull.
post #11 of 31 Old 12-22-2009, 08:46 AM
jeepinmichguy_
jeepinmichguy_'s Avatar
pee on it and it will unfreeze!
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #12 of 31 Old 12-22-2009, 08:59 AM
unsung
unsung's Avatar
Mine was doing the exact same thing a few days ago. I didn't do anything but now it works.
unsung is offline
post #13 of 31 Old 12-22-2009, 09:00 AM
mikesbeachhut
Same thing happened to me in my yj years ago .Had to buy a new inside door handle.There is a metal rod that connects to a plastic lever on the inside door handle unit that strips when you try to force it open when frozen.Take the door panel off(a few screws,then pry cover off).You will see a metal rod that runs from the door latch to the door handle fell out .(pain in the a-- to fix).
mikesbeachhut is offline
post #14 of 31 Old 12-22-2009, 09:24 AM
27mtaylor
happened to me a few years ago. Best I can remember there was a plastic piece that broke when I forced the handle back. I was able to take some wire that I had around the house and use it to link the mechanism back. It has worked for 2-3 years now.
"97 TJ, 4.0, 3" Black Diamond Suspension, 2" body lift, JKS disconnects, Borla Exhaust, 35x12.50x15 BFG MT's, G2 Dana 44 Rear Axle Detroit Locker
27mtaylor is offline
post #15 of 31 Old 12-22-2009, 09:30 AM
black05tj
2017 JK Wrangler
Originally Posted by mikesbeachhut View Post
Same thing happend to me in my yj years ago .Had to buy a new inside door handle.There is a metal rod that connects to a plastic lever on the inside door handle unit that strips when you try to force it open when frozen.Take the door panel off(a few screws,then pry cover off).You will see a metal rod that runs from the door latch to the door handle fell out .(pain in the a-- to fix).
I would think the outside handle would still work even if the inside handle was broken... But, if the inside handle is broken and the rod has fallen and is jamming something to prevent the outer latch from opening, you may be able to remove the inside latch and have enough of an opening to fish a coathanger in there and snag the rod. This should allow you to open the door, I would think...
If you see Hobbes, tell him I said "Hi".
black05tj is offline
Runnin Doors Off- Where To Put Doors In Jeep? jbpdog TJ Wrangler Technical Forum 64 03-28-2018 09:43 AM
Half doors to full steel doors - '94 body, '88 doors xponce YJ Wrangler Technical Forum 8 02-20-2010 03:29 PM
F.M.JEEP! stupid doors frozen again bpeterson TJ Wrangler Technical Forum 23 12-22-2009 08:44 PM
Doors frozen 98_classic TJ Wrangler Technical Forum 15 01-16-2009 02:46 PM
My door was frozen open this morning now its frozen shut 01amberfirewv TJ Wrangler Technical Forum 9 02-03-2007 04:29 PM
