Intervention for suspension - JeepForum.com
post #1 of 9 Old 08-24-2011, 04:04 PM Thread Starter
cjtheodo
Would like to buy all upgrades from Savvy but can't quite swing the 3" suspension systerm. probably someday. But I have the underarmor and 1.25" body lift. I want just enough to fit 33's. since they say that their UA fits with their 3 inch lift kit then I'd assume its the bumpstops that prevents the contact between suspension and under armor. So what I'd like to do is get some 2" procomp coil springs with rancho 9000 shocks and get the bump stops from savvy. throw in the antirock from savvy for good measure. Sound like a good plan? This way if I want to go bigger in the future I just have to replace the springs and add on other suspension mods (control arms, traction bar...ect)
cjtheodo is offline
post #2 of 9 Old 08-24-2011, 04:08 PM
RubiconRazorbac
RubiconRazorbac's Avatar
What are your plans for addressing driveline angles?
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #3 of 9 Old 08-24-2011, 05:06 PM Thread Starter
cjtheodo
the savvy under armor comes with a 1 inch motor mount lift. hopefully a small 2 inch lift and mml will prevent any of those problems
cjtheodo is offline
post #4 of 9 Old 08-24-2011, 06:10 PM
RubiconRazorbac
That's quite a gamble. Good luck.
2003 TJ Rubicon:
2017 JKU Rubicon:
post #5 of 9 Old 08-24-2011, 06:16 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
you will need an SYE.
I've got a 10" longer driveshaft and I needed a SYE with a small 2.5" lift and a tummy tuck thats lower than the Savvy.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #6 of 9 Old 08-24-2011, 06:31 PM
RubiconRazorbac
I have a feeling he's going to have to learn the hard way...
2003 TJ Rubicon:
2017 JKU Rubicon:
post #7 of 9 Old 08-24-2011, 07:24 PM
biffgnar
biffgnar's Avatar
Yes, but UA tucks your tummy 3"+. You think an MML alone will adjust for 5"+ of change in driveline height?
biffgnar is offline
post #8 of 9 Old 08-24-2011, 08:24 PM
kelso1337
kelso1337's Avatar
The only way to do things right is to do it right the first time.
You know what they say: Research, research, research.
And if you still can't iron out the fuzzy points, ask the professionals.
Stock 2003 Jeep TJ - 'Intense Blue'
Bought the jeep in April, found JF in May...
First Mod in June.
kelso1337 is offline
post #9 of 9 Old 08-25-2011, 05:05 AM
csm41
Listen to what he is saying here. You will need at least some adjustable upper arms back there and most likely rear lowers also. Then, a new custom driveshaft. We've all been there already.
I hope the OP listens or I fear you are correct. A hard lesson it is.
csm41 is offline
Confused. Why 4" suspension lift plus body lift instead of taller suspension lift? ezgoin TJ Wrangler Technical Forum 34 02-12-2011 06:04 PM
Long Arm suspension...vs short arm suspension GMC7000 TJ Wrangler Technical Forum 105 11-09-2010 08:46 PM
Rubicon suspension vs. Islander/Mountain suspension GXP20T JK Wrangler Technical Forum 11 08-25-2010 07:54 PM
2" Suspension + 1" Body VS 3.5" Suspension tx_medic YJ Wrangler Technical Forum 13 06-17-2009 08:43 PM
OME 2.5'' suspension kit or Rancho 2.5'' Rockcrawler suspension kit? billabong266 TJ Wrangler Technical Forum 23 04-23-2009 01:05 PM
