Installing Daylighters - JeepForum.com
post #1 of 3 Old 05-29-2002, 08:24 PM Thread Starter
mihiinme
I know this is going to make somebody scream, but I have searched all the posts, read and put them all together. Long story short I must be a dumb s^*#. Can anyone give the step by step, idiot proof instructions on how to wire KC Daylighters to stock switch? 2000 TJ w/o factory fogs. I have the switch in. Got something done right? I must get some credit for that? LoL Please somebody walk me through this..
00 TJ 4.0 manual hardtop bone stock "for now" :)
mihiinme is offline
post #2 of 3 Old 05-30-2002, 08:50 AM
Parajeeper
Guest
Go to:
<a href="http://www.stu-offroad.com/misc/lights-1.htm" target="_blank">http://www.stu-offroad.com/misc/lights-1.htm</a>
Detailed wiring instructions
Parajeeper is offline
post #3 of 3 Old 05-30-2002, 07:59 PM
Rhett
Guest
If it didnt come with the factory fogs then it doesnt have a factory switch. At least mine doesn't. I used a switch from one of the cheap K-mart light kits that are for the daylighter look alikes and it fit directly into my switch hole and looks like it is suppose to be there.
You will need to take of the radio and heater control bezel it just unscrews up on the dash and has one bolt behind the ashtray and it is out. I think they are all 10mm bolts. you will find factory rubber cowl fillers in the cowl "firewall" behind the engine you can pop these out and run your wire through. and pop it back in and it will seal pretty well.
Rhett is offline
aftermarket light
Help installing daylighters? Craig1319 YJ Wrangler Technical Forum 22 12-19-2008 08:43 AM
kc daylighters Pathogen1337 TJ Wrangler Technical Forum 30 05-02-2008 11:09 AM
Installing KC Daylighters - how to? wyldejackyl TJ Wrangler Technical Forum 4 08-20-2004 11:40 AM
hmm Daylighters Shortbord1 TJ Wrangler Technical Forum 0 07-09-2004 04:35 PM
ron kc daylighters BigD1634 YJ Wrangler Technical Forum 1 11-14-2001 11:04 AM
