Ignition Switch Actuator Pin Repair - JeepForum.com
post #1 of 3 Old 03-19-2011, 10:16 AM Thread Starter
jdgrip
2004 KJ Liberty
Ok, had an issue where I couldn't get car to shut off. Thought it was the ignition switch, bought new one for $14 at the local parts store. Installed part, nope, not it. I undid the 2 torx head screws between the ignition switch and ignition cylinder and found the issue, a broken actuator pin. Went to the local junkyard and pulled the part from a plymouth neon and installed. Car now starts and shuts off.
Here is a link to the video that helped me out.
Jdgrip
jdgrip is offline
post #2 of 3 Old 03-19-2011, 02:32 PM
oakmckinley
oakmckinley's Avatar
Nice video.
oakmckinley is offline
post #3 of 3 Old 04-13-2012, 10:28 PM
RawLo
hell yeah! This just happened to me today, stuck at Food 4 Less on friday the 13th... key turns, won't start- but everything stays on. Thanks so much for posting this video, total life-saver!
RawLo is offline
Hot Air Again! Blend Door Actuator Repair Savvy TJ Wrangler Technical Forum 41 10-26-2016 01:26 PM
Ignition actuator pin roughknight69 TJ Wrangler Technical Forum 1 12-08-2010 05:18 PM
T-case vacuum switch actuator? TrynPas YJ Wrangler Technical Forum 14 04-18-2010 11:35 PM
Vacuum Actuator Switch 4wd HanksRide YJ Wrangler Technical Forum 1 02-02-2010 07:19 PM
Epic Ignition Battle (replaced everything but the ignition switch!) thechadwick YJ Wrangler Technical Forum 10 08-27-2009 11:02 PM
