Ignition failure requires new steering column? - Page 2 - JeepForum.com
post #16 of 35 Old 10-29-2011, 11:41 PM
rubee
space ball.....i am a chick haha
rubee is offline
post #17 of 35 Old 10-30-2011, 12:10 AM
OSjeeper
I have 4 of the parts your looking for free for the asking.
OSjeeper is offline
post #18 of 35 Old 10-30-2011, 11:48 AM
Spaceball
Spaceball's Avatar
OOPS! Sorry Ma'am my bad! Sounds like a great deal from OSjeeper.....
Spaceball is offline
post #19 of 35 Old 10-30-2011, 01:01 PM
rubee
the part is ordered! lets pray it fixes the issue! it has been very tempermental, starts when its been sitting a while, doesnt start when its been sitting for a short while or just a few hours. had to pop the clutch twice yesterday. luckily the 2nd line i backed up into my parents driveway thats a little hill and was able to pop it myself rolling down the damn thing. thanks again for the help and info! i bought the part from RockAuto!
rubee is offline
post #20 of 35 Old 10-30-2011, 01:02 PM
rubee
rubee is offline
post #21 of 35 Old 10-30-2011, 01:04 PM
rubee
no worries spaceball....im sure theres not very many women on here! haha
rubee is offline
post #22 of 35 Old 12-01-2011, 07:45 PM
adamdvw
Just fixed this on my 03, this video was very helpful:
http://www.rockauto.com/catalog/moreinfo.php?pk=2546988
'03 Sahara
4.0L, 5 Speed
RE 3.5" Lift
33x12.5 BFG A/T's
SYE/CV Driveshaft
adamdvw is offline
post #23 of 35 Old 01-24-2012, 08:36 PM
RecklessNOBO10
I'm having a similar problem and think this may be the solution. Is there any way to visually/mechanically tell if the ignition switch acuator is bad?
thanks
RecklessNOBO10 is offline
post #24 of 35 Old 01-25-2012, 12:51 AM
kyleboender
Very simple repair. For mine (and I assume other jeeps) I needed a tamper proof torx set (torx set with the hole in the middle)
Good luck
New Jeep Project. 2003 TJ... Third time's the Charm.
2005 LJ "Alberta LJ"
1998 XJ https://www.jeepforum.com/forum/f11/project-xj-made-steel-rebuild-900095/
kyleboender is offline
post #25 of 35 Old 01-25-2012, 05:17 AM
Slacksuperstar
Slacksuperstar's Avatar
Mine broke robbed one out of an 01 cherokee 2 dollars later it was like brand new.
Slacksuperstar is offline
post #26 of 35 Old 01-25-2012, 06:16 AM
gyastine
Question: How do you separate the actuator pin from the ignition?
gyastine is offline
post #27 of 35 Old 01-25-2012, 11:32 AM
Jonny Jeep
Jonny Jeep's Avatar
Watch the video.
Jonny Jeep is offline
post #28 of 35 Old 01-26-2012, 06:11 AM
RecklessNOBO10
Ok.....So I took apart the ignition configuration. My ignition switch actuator pin is NOT broken. I CANNOT start up the jeep with a screwdriver either so I think I am ruling out ignition problems up to that point? I"m not really sure where to go from here. My starter is good, battery is good, starter relays good, all fuses good, wire from battery to starter good, no reading on meter from the wire that goes from the colenoid/starter to the ignition, but the wire seems to be ok (no visual deficiencies). Does anyone have any ideas???? I neeeeeed my jeeeeeep.
post #29 of 35 Old 01-26-2012, 08:13 AM
Slacksuperstar
Possibly a bad switch?
post #30 of 35 Old 07-31-2012, 01:25 PM
dfechter
Same problem, simple fix
I had the EXACT same problem with my '05 Wrangler X. Dealer said steering column needed to be replaced - about $1000. I visited this forum and thanks to everyone's input I ended up getting a new ignition actuator from RockAuto for about 30 bucks, plus maybe $10 for express shipment. Worked like a charm.
dfechter is offline
Steering Column/Ignition "Push to start" rod - 91 YJ jesseleikerjeep YJ Wrangler Technical Forum 20 10-27-2010 07:45 AM
broke steering column ignition pin redsled1217 TJ Wrangler Technical Forum 4 10-22-2009 03:36 PM
Jeep Dies After Ignition, Requires Throttle to Avoid Stalling 01TJfuntime TJ Wrangler Technical Forum 7 10-11-2009 11:10 PM
Ignition Problem - How hard to replace steering column? stereoman405 TJ Wrangler Technical Forum 0 03-31-2008 05:16 PM
Steering column ignition switch question Charlie L YJ Wrangler Technical Forum 0 03-22-2002 06:56 PM
