Ignition failure requires new steering column? - JeepForum.com
post #1 of 35 Old 10-26-2009, 08:23 PM Thread Starter
jeep-rambler
My 2006 Jeep Wrangler Sport just started failing to start. I can turn the key in the ignition all the way, with no resistance and no activation; absolutely nothing, the starter does not even attempt to engage. The dash lights come on, and because it offers no resistance to full engagement, I believe it to be mechanical in the key mechanism, not electrical.
At first I thought it might just be the ignition key cylinder, but was not sure. I had it towed to the local dealer, because I still don't know of a good Jeep mechanic in my area, San Jose, CA...
Got a call back from the dealer today, explained the problem and what I thought was the cause. They took a look and called me back. They say the entire steering column needs to be replaced. This will be a very costly repair...
Does this sound right to folks? Any ideas why a failure for the ignition key mechanism would require the full steering column to be replaced? Are there questions I should ask the service advisor, to ensure that I really am being steered (heh, pun intended) to required service, rather than being taken to the cleaners?
jeep-rambler is offline
post #2 of 35 Old 10-26-2009, 09:11 PM
mudb8
want it rite or rite now?
mudb8's Avatar
that's bs...
there is a pin that the connects the key cylinder to the switch that breaks.... pm rubirock, he has a source for such parts.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #3 of 35 Old 10-27-2009, 02:48 AM
Jonny Jeep
Jonny Jeep's Avatar
Also check out D A V E Y S J E E P S . C O M - Parts Specials
Look for this about 1/3 down.
Jonny Jeep is offline
post #4 of 35 Old 10-27-2009, 06:04 AM
mobyjeep
mobyjeep's Avatar
The dealer doesent sell the "pin" seperately, it is part of the steering column. My local dealer quoted $350 for the part. I ordered just a used pin from Daveys Jeeps for $83 delivered. I'm using a screw driver to turn the ignition switch until I get the part.
mobyjeep is offline
post #5 of 35 Old 10-27-2009, 09:12 AM
RubiRock
yup, davey's jeeps is where I got my ignition "tumbler". great deal, especially when the local guy wanted $350 for the same part.
i'm willing to bet that the OP's problem is the same as mine. I would definitely have them stop work on your rig and order the part from davey's, it is an easy fix and will save you a couple hundred dollars.
01.5 S4
RubiRock is offline
post #6 of 35 Old 10-27-2009, 10:53 AM Thread Starter
jeep-rambler
Thanks everyone, I'm gonna ask the dealer whether it is just the ignition pin that has borked, and if so, I'll order the part.
Anyone know of a good Jeep shop in the San Jose, California area?
I'd work on it myself, but I've nowhere to work on it (live in a condo complex with a policy against that). I know, pretty stupid getting a Jeep with nowhere to work on it, but hey...
post #7 of 35 Old 10-27-2009, 12:38 PM
RubiRock
I'm pretty sure you could get away with fixing this @ your condo complex, that is unless they have a policy against you sitting in your jeep. all you need to do is removed the column cover and move the switch stalks, then you simply pop the part in and close it up. you could easily do it all from the drivers seat with the door closed, if you had to.
01.5 S4
RubiRock is offline
post #8 of 35 Old 10-27-2011, 11:23 PM
rubee
i am having the same problem, just last week i noticed when i turned the key to start all lights came on but would have issues turning on then turn back and try again and it would start. then one day it didnt start at all. had to pop the clutch to go. didnt drive it for a day, came back that night it started right up but replaced the starter anyway. then seemed to be ok for a few days, then same issues again, a couple turns to start. then tonight no start at all......sounds like my steering column pin is broke also? i have a 06 rubicon.
rubee is offline
post #9 of 35 Old 10-27-2011, 11:37 PM
psouza1943
Try Greenwood Jeep Chrysler Dodge in Gilroy. They have treated me very well for the last three years with my two Jeeps and Dodge Diesel truck. No BS and seem willing to work with me on ANYTHING. I've been screwed by the best (worst) of 'em. These guys are refreshingly different....but YMMV. Be aware, however, that reduced inventory stocking may bite you in the butt when it comes to your situation, and no dealer will be of much help. Unless they are into salvage parts. You have already received good advice for DIY. If you meant a Jeep custom shop, check out Arabias in Campbel www.arabiasoverkill.com/
psouza1943 is offline
post #10 of 35 Old 10-28-2011, 12:12 AM
Jonny Jeep
Jonny Jeep's Avatar
If it is the ignition pin rockauto have them new cheaper than daveys used price. I believe you may find them cheaper still on amazon. If it is the pin you should be able to see it's broken by removing the ignition switch. There's a video linked from rockauto showing how to replace the pin as the steering lock pin needs to be removed.
post #11 of 35 Old 10-28-2011, 06:26 AM
Spaceball
Spaceball's Avatar
I took a couple of those ignition pins/actuators (1 for a spare) from Dodge Neons at the pic-a-part. Cost a whopping $3!
Spaceball is offline
post #12 of 35 Old 10-28-2011, 03:45 PM
rubee
lol dodge neon might be a lil different then a jeep maybe
rubee is offline
post #13 of 35 Old 10-28-2011, 03:52 PM
rubee
JONNY JEEP : hey is it the 2006 JEEP WRANGLER RUBICON 4.0L 242cid L6 FI (S) OHV : Ignition : Ignition Switch Actuator Pin WikiPriceDORMAN Part # 924704 Ignition Switch Actuator Pin
$25.89
rubee is offline
post #14 of 35 Old 10-28-2011, 06:56 PM
Spaceball
Spaceball's Avatar
No sir! Same part, read this thread I had the same problem on my Jeep.
https://www.jeepforum.com/forum/f9/20...59/index2.html
post #15 of 35 Old 10-29-2011, 10:15 AM
Jonny Jeep
Jonny Jeep's Avatar
That's the one.
Steering Column/Ignition "Push to start" rod - 91 YJ jesseleikerjeep YJ Wrangler Technical Forum 20 10-27-2010 06:45 AM
broke steering column ignition pin redsled1217 TJ Wrangler Technical Forum 4 10-22-2009 02:36 PM
Jeep Dies After Ignition, Requires Throttle to Avoid Stalling 01TJfuntime TJ Wrangler Technical Forum 7 10-11-2009 10:10 PM
Ignition Problem - How hard to replace steering column? stereoman405 TJ Wrangler Technical Forum 0 03-31-2008 04:16 PM
Steering column ignition switch question Charlie L YJ Wrangler Technical Forum 0 03-22-2002 05:56 PM
