Are the Idler Pulley & Tension Pulley Interchangeable? - JeepForum.com
 3Likes
  • 1 Post By mukluk
  • 1 Post By tworley
  • 1 Post By ibikee
post #1 of 8 Old 01-16-2020, 11:52 AM Thread Starter
joeyroe
I'm confused...
Some companies sell these pulleys as the same part, but others list them separately. Does anyone know if, in fact, they are interchangeable...or are they completely different parts?
Thanks in advance.
joeyroe is offline
post #2 of 8 Old 01-17-2020, 12:59 AM
mukluk
mukluk's Avatar
From what I can tell, if your engine has a tensioner pulley with manual adjustment then the tensioner and idler pullies are the same. If your engine has an automatic tensioner however, its pulley is a tad smaller in diameter than the idler pulley.
joeyroe likes this.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 8 Old 01-17-2020, 09:50 AM
tworley
tworley's Avatar
My research a while back showed the manual adjustment pulleys were a 76mm for the idle and 90mm for the tensioner.
joeyroe likes this.
Colorado Member 307
tworley is offline
post #4 of 8 Old 01-18-2020, 07:12 AM
ibikee
ibikee's Avatar
@mukluk How much is a “tad” ?
ibikee is offline
post #5 of 8 Old 01-18-2020, 08:16 AM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
1 tad = 14 mm
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
post #6 of 8 Old 01-18-2020, 11:22 AM
ibikee
ibikee's Avatar
@NashvilleTJ Wow. 14mm is a lot of tad. I presumed it was a tad less
NashvilleTJ likes this.
ibikee is offline
post #7 of 8 Old 01-18-2020, 12:39 PM
CJRoberts8812
The Muddog is a 2002, 4.0, standard trans. A few years ago, (three or so), I detected a squeal from the Tensioner Pulley. When I did my research, I found that both pulleys were the same. I ordered two of the same part number, replaced both, and have not had any trouble.
CJRoberts8812 is offline
post #8 of 8 Old 01-18-2020, 07:12 PM
mukluk
mukluk's Avatar
On my '05 LJ the idler is 76mm and the tensioner is ~71mm, so ~5mm difference.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
