I only have defrost, nothing else.. - JeepForum.com
post #1 of 5 Old 03-03-2010, 11:15 AM Thread Starter
05LjNj
What could it be? My speeds work from my hvac but its the settings I only always have defrost and sometimes feet. Temp and speed are good. What gives?
'05 Wrangler Unlimited, BDS 3", 33's, Blah blah
'00 Cherokee Sport... Stock.
80,000 miles and counting on the booty 0331 head
05LjNj is offline
post #2 of 5 Old 03-03-2010, 11:23 AM
GilaMtnJeep
GilaMtnJeep's Avatar
You have a vacuum problem. Mine did the exact same thing. For me it was the vacuum line where it attaches to the resevoir under the battery tray. Search the TJ forum, there is a thread telling how to troubleshoot and repair it, whatever it is.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #3 of 5 Old 03-03-2010, 11:28 AM
Scotch740
Scotch740's Avatar
Did you serach and try this?
https://www.jeepforum.com/forum/f9/va...9/#post4254601
If that fixes it PM me and I will send you my address and you can mail me a beer Cheaper than flying down here and buying me one
Also when your troubleshooting a problem over the internet you need to provide more information. Did it happen all at once? Over time? Any recent work under the hood? ect...
Scotch740 is offline
post #4 of 5 Old 03-03-2010, 11:35 AM
Mino
Mino's Avatar
Yup, sounds like a vacuum issue. I was working on my Throttle Body one day and accidentally disconnected a vacuum line from the manifold and had the exact same issue you have. Reconnected the vacuum line and corrected the problem. Good luck.
'05 Jeep Wrangler X
Rocky Mountain Edition
3" suspension lift, K&N cold air intake, Pro Comp MX6 shocks, JKS Quicker Disconnects & Front Track Bar, Dynomax Cat-Back system, SYE kit, Pro Comp Rock Crawler Wheels, 33" BF Goodrich A/T, Aussie Locker, and Warn XD9000i winch
Mino is offline
post #5 of 5 Old 03-03-2010, 05:17 PM Thread Starter
05LjNj
got it, thanks for the link scotch.. there was a lose plug coming off the engine
I love it when this stuff works out so easily (rare)
05LjNj is offline
TJ has no defrost gob129 TJ Wrangler Technical Forum 10 02-01-2014 08:42 AM
AC blows when I have defrost or defrost/feet selected Marholmes44 TJ Wrangler Technical Forum 2 01-18-2009 06:18 PM
No defrost or Max AC 1FSTLS1 TJ Wrangler Technical Forum 8 11-19-2008 01:59 PM
Defrost CTMpwrdcamry TJ Wrangler Technical Forum 3 12-17-2004 06:44 PM
No defrost EDM0656 TJ Wrangler Technical Forum 4 10-26-2003 10:03 AM
