i hate torx bolts - JeepForum.com
post #1 of 16 Old 07-28-2007, 01:05 AM Thread Starter
badoosh27
badoosh27's Avatar
i hate torx bolts
i just spent 2 hours drilling out a stupid torx bolt in the windshield. i broke 4 drill bits and scratched my paint. I have a nice set of torx wrenches that fit on a socket wrench deal, but they seem to strip out really easily. how do yall get them out when they start to strip? i know sears has those reverse drill bits that can get them out, but i cant really spend $40 or whatever they cost. any help is appreciated and im sure others would like to know as well...
2001 Wrangler Sport 4.0, 5 speed, 30/35 axles, 3.73's, ZJ springs, 1"BB, 31" Futura M/Ts
badoosh27 is offline
post #2 of 16 Old 07-28-2007, 07:05 AM
Rocky529
Rocky529's Avatar
Easy Out from Sears works well usually.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 16 Old 07-28-2007, 07:08 AM
JeepRide
JeepRide's Avatar
this wont help now but in the future when removing torx bolt after you insert bit try tapping bit firmly into bolt head
98 xj 4.0L 231 / aw4 /8.25/3.55
31x10.50 a/t 3 inch bastard lift
JeepRide is offline
post #4 of 16 Old 07-28-2007, 07:28 AM
Muddeprived
Muddeprived's Avatar
I learned that before trying to turn the bolt, take a hammer to the torx socket and pound it in some more. This gives you a better grip. Also apply heavy pressure to the torx socket while you are turning, as in leaning on it but make sure you keep the socket as straight as possible. You could have another person lean on the socket wrench, applying pressure, while you turn it. An impact gun would help alot i believe. Impacting while turning loosens bolts easier.
How i got mine out after stripping one:
I took a dremel and sliced a groove right down the middle of the bolt head so it had a "flat head screwdriver" slot. I took my HD large flat head screwdriver (1/2" head) and pounded that into the slot. Next i took my vice grips and locked them on the screwdriver shaft and turned it with the vice grips. You gotta make sure the groove that you slice on the bolt head is deep enough not to strip.
2001 XJ Sport 4.5" LA
1999 TJ 2.5L 5spd 2" lift
Muddeprived is offline
post #5 of 16 Old 07-28-2007, 08:13 AM
Rule303
Guest
Mine did the same thing.
I second the tapping the bit in with a hammer trick. The painted screw heads keep the bit from correctly fitting.
Rule303 is offline
post #6 of 16 Old 07-28-2007, 02:15 PM
trail97
Guest
some posted the idea of using an impact hammer driver, use hammer to activate rotation on tool? anyway others chimed in that it worked like a charm and is available at sears for twenty something bucks, (for the future) Good Luck!!
trail97 is offline
post #7 of 16 Old 07-28-2007, 02:24 PM
Chris @ GATR
Chris @ GATR's Avatar
ALWAYS spray a Jeep torx bolt head with some PB Blaster prior to trying to remove and it will come out, usually without a lot of force. Also, before trying to loosen, put some brute force on it in the "tightening" direction to unseat the threads, then reverse and it will usually back out easier.
Got ignorance? Please see below.
Originally Posted by kd4yor View Post
Chris, I just think your having buyers remorse for all the work in your 8.8 for no added gain (over the Dana 35).
Chris @ GATR is offline
post #8 of 16 Old 07-28-2007, 02:27 PM
omgsideburns
yeah you should be able to undo torx bits with just a hand driver.
i've never stripped a torx bit, my vw was COVERED in them.
omgsideburns is offline
post #9 of 16 Old 07-28-2007, 03:45 PM
arbby
2005 KJ Liberty
|l,[___],
l---L--OlllllllO
()_) ()_)--o-)_)
Gone: 1993 YJ
arbby is offline
post #10 of 16 Old 07-28-2007, 04:08 PM
BlkBird
Guest
Ive never stripped one either. I was wondering how you guys are stripping hardened bolts?
BlkBird is offline
post #11 of 16 Old 07-28-2007, 04:33 PM
jeeptrix
jeeptrix's Avatar
2009 JK Wrangler
I stripped one. I am new to working on vehicles and just thought it was a fancy shaped allen wrench lol. Then figured out I was wrong when I stripped it, got the torx bit, and still couldn't get them out. So I took it to the shop of a guy that kinda owes me some favors, and he hammered his nice Snap-on torx bits in and got em right out for me. I don't tighten them as much now
jeeptrix is offline
post #12 of 16 Old 07-28-2007, 04:40 PM
lrjeep
Guest
So you would much rather have phillips which cam out really easy comparably? The only bad thing to me with torx is the fact I have to carry around a whole set of torx drivers. Other than that I much prefer them to any other screw drive method.
lrjeep is offline
post #13 of 16 Old 07-28-2007, 05:13 PM
Rule303
Guest
Its the paint that fills the holes that causes them to strip if you aren't careful. The unpainted ones , I never have had a problem with.
Rule303 is offline
post #14 of 16 Old 07-28-2007, 08:50 PM
omgsideburns
there ya go arrby, don't roll your eyes at me.
stripped a few allens out though, ick.
post #15 of 16 Old 07-28-2007, 09:12 PM
CNY
Another handy tip. Pound that Torx bit in there, and heat the Torx bit.
Not cherry red (unless you have another bit, because you'll change the temper of your first one).
Heat, PB Blaster, hitting the bit...... repeat. And, if you don't have an air impact wrench, get a manual one. It lets you do the hitting and turning all at the same time.
And, if these are completely painted-over, make sure to slit the paint, to get the PB Blaster working in there.
Easy outs might work on some stripped fasteners.... but if you stripped these bolt out, they are stuck so tight that they will not "easy-out".
CNY is offline
Torx head starter bolts - Anyone know what kind of bolts? patricknolan TJ Wrangler Technical Forum 0 08-13-2009 08:02 AM
It's Official...I now [B]HATE[/B]Torx Bolts dmac27 YJ Wrangler Technical Forum 6 07-27-2009 11:30 PM
I Hate Torx!!! ImportEater Wrangler General Discussion 30 05-31-2008 01:53 AM
Torx bolts, oh how I hate thee admar2 YJ Wrangler Technical Forum 13 06-16-2005 05:41 PM
i hate torx bolts. breaker bar? toyotasupra TJ Wrangler Technical Forum 5 09-20-2003 02:25 PM
