I didn't realize it was so easy to falsify odometer readings. - JeepForum.com
post #1 of 9 Old 05-25-2013, 10:09 AM Thread Starter
Vinman
I picked up a wrecked Rubicon and swapped the mint black interior into my LJ,
In the process I picked all the nicest dash components as I reassembled my dash, I got quite a surprise when I used the gauge cluster from the donor Jeep and the mileage and VIN from the donor Jeep now registered on mine.
I thought those pieces of info would have been stored in the PCM and not just the cluster.
I then reinstalled my original higher mileage cluster.
Vinman is offline
post #2 of 9 Old 05-25-2013, 11:25 AM
TJJP77
TJJP77's Avatar
I think it is stored in both places. Had you driven the Jeep around for a bit, I believe the cluster would have automatically updated to the higher mileage stored in your PCM.
Chris
'02 Sahara
'06 Rubicon Unlimited
Sienna Jeep Club: Member #15
TJJP77 is offline
post #3 of 9 Old 05-25-2013, 11:35 AM
biffgnar
biffgnar's Avatar
Nope. It is very common in XJ world for the dash connections to have issues (and it happens occassionally in TJ world). XJ guys often swap their dashes and have the "wrong" mileage. Only way to get correct mileage to show up on dash is to buy new dash unit from dealership where they want something like $1k for it. PO of my XJ actually paid that at the dealership. Lots of threads about this over in the XJ forum.
biffgnar is offline
post #4 of 9 Old 05-25-2013, 12:46 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
It is also stored in the PCM. Been through that several times redoing and swapping around PCM's for SKIM and Auto swaps.
The dealer needs some method to program either with the correct mileage if one of the two is replaced.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #5 of 9 Old 05-25-2013, 02:17 PM
biffgnar
biffgnar's Avatar
It may be there but it won't automatically update the console as suggested
biffgnar is offline
post #6 of 9 Old 05-25-2013, 05:44 PM Thread Starter
Vinman
It also intrigued me with VIN of the donor vehicle being displayed. It could be used as another tool to assist in verifying the cluster has not been changed by the seller to falsify the mileage readings.
Vinman is offline
post #7 of 9 Old 05-25-2013, 05:53 PM
DoctorTim
DoctorTim's Avatar
for XJs without a digital odometer, you can easily adjust the mileage by popping it open, taking out the odometer number-wheel thingy, pulling back the little washers, and adjusting the numbers. I did it when i had to get a cluster from a wrecked XJ.
DoctorTim is offline
post #8 of 9 Old 05-25-2013, 07:23 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
could have sworn they can do it with the drbiii for either the dash or pcm and it's a half hour labor charge.
the early mechanical odometers are easy to turn, the later ones are generally very tamper proof.
ratmonkey is offline
post #9 of 9 Old 05-25-2013, 09:21 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I believe you are correct.
I am Savvy
mrblaine is offline
