How Should I Seal My Radiator Shroud? - JeepForum.com
 4Likes
  • 1 Post By mukluk
  • 1 Post By SkylinesSuck
  • 1 Post By Jeepsr4me
  • 1 Post By freedom_in_4low
post #1 of 10 Old 08-22-2019, 05:29 PM Thread Starter
joeyroe
I'm happy with my brass/copper radiator, but I'd like to find a way to seal the gap between the shroud and radiator.
Besides replacing the radiator, does anyone have any ideas (ie: maybe some heat resistant foam trim)??
Thanks in advance.
joeyroe is offline
post #2 of 10 Old 08-22-2019, 05:51 PM
mukluk
mukluk's Avatar
That's what the factory uses to seal the gap between the radiator and AC condenser, safe bet it'd work for what you want as well.
joeyroe likes this.
2000 TJ SE
2005 LJ Rubicon
mukluk is online now
post #3 of 10 Old 08-22-2019, 07:29 PM
SkylinesSuck
I used whatever foam I found at Home Depot for sealing windows and it has held up fine.
joeyroe likes this.
'98 Sahara w/AX15 & 4.6L stroker, 2.5" OME lift, 32" BFG M/T's, 8.8 w/Detroit Trutracs & 4.10's F&R
SkylinesSuck is offline
post #4 of 10 Old 08-22-2019, 07:49 PM Thread Starter
joeyroe
Thanks for the suggestions! Do you think something like this might work too (trimmed to fit, of course)...?
joeyroe is offline
post #5 of 10 Old 08-23-2019, 07:20 AM
SkylinesSuck
I think that won't melt. Not sure how well it would fit in your application but I'm guessing you could make it work.
post #6 of 10 Old 08-23-2019, 05:18 PM
Jeepsr4me
At Lowes there is a flat foam tape.. Its about 1/4 to 1/2 inch thick. Pull the shroud and stick that to the edge.
The foam is for areas that get hot so it will work just fine. And seeing as it will be pressed together between the rad and shroud it will not come off.
https://www.lowes.com/pd/M-D-10-ft-x...rstrip/3120621
joeyroe likes this.
Jeepsr4me is offline
post #7 of 10 Old 08-27-2019, 01:17 PM
freedom_in_4low
it's your Jeep so by all means seal the gap if you want, but I would not expect it to solve any overheating problems if you have them. You're losing way more airflow between the fan shroud and fan impeller blade tips than between the shroud and the radiator.
Joe
1999 TJ Sahara
2008 MINI Cooper S
2010 Toyota 4Runner
freedom_in_4low is offline
post #8 of 10 Old 08-27-2019, 03:51 PM Thread Starter
joeyroe
Yea, I actually agree, and already ordered a Mopar Radiator. Hopefully it will not only cool better, but also fit my shroud better.
joeyroe is offline
post #9 of 10 Old 08-27-2019, 03:54 PM
freedom_in_4low
Last year, my TJ was getting hot on the highway, after I had done a motor mount lift and moved my shroud to match the fan (so it sat about 1" higher on the radiator than previously, so the bottom 1" of the fins aren't even inside the shroud at all). I spent some time blaming that to no avail but I finally put in a new Mopar radiator and haven't even seen 210 since.
joeyroe likes this.
Joe
1999 TJ Sahara
2008 MINI Cooper S
2010 Toyota 4Runner
post #10 of 10 Old 08-29-2019, 04:51 PM Thread Starter
joeyroe
Update:
Just installed a new Mopar radiator. Shroud fits much tighter now (big difference), and tomorrow I'll test the radiator in the desert
joeyroe is offline
