How often should my wife drive my jeep? - Page 2 - JeepForum.com
post #16 of 27 Old 12-30-2009, 09:01 AM
Deezelweazel
An engine is designed to work under load.
Idle allows lateral movement of the crank, con rods and pistons.
This movement combined with the cold engine temperature is the worst thing you could do to an engine.
Wear is accelerrated.
Acids and humditiy developed during idle have to be absorbed by the oil.
It takes a long time to reach operating temperature- Don't get fooled by the water temps- oil is still cold.
But it develops its lubricity best at operational-temp.
A lot of fuel has to be injected during idle to overcome friction. Not all of this fuel gets burned.
It dilutes the oil. Oil looses the viscosity because gas has no lubing abilities.
This dilluted oil is pressed through the bearings. Bearings are sensitive to non circular movements caused by the lateral movements with no load. And the cycle closes its ring. Accelerated wear of the bearings (bearings are very sensitive to all movements without that lubing oil pressure film between the bearing and the crank), more play in the bearings, lack of oil pressure- a worn out engine.
Of course this not to recognize during idle-it's a slow and unrecognized process over months and years.
Just avoid extended idle times.
It's different for turbo engines. They need idle to lube the turbo bearing to avoid wear. But it is a process timed in seconds until oil pressure is up. Not for minutes and long times!
Deezelweazel is offline
post #17 of 27 Old 12-30-2009, 09:40 AM
Dabbill
My wife cant drive a stick. So my step dad drives my jeep once or twice a week to work to keep stuff lubed up. Will be nice once I can get home from Afghanistan to drive my jeep again.
Dabbill is offline
post #18 of 27 Old 12-30-2009, 09:46 AM
rshives
lol I was going the complete other way until I realized the reasoning behind you wanting her to drive it.
Thanks for your service.
rshives is offline
post #19 of 27 Old 12-30-2009, 10:46 AM
Turner
Turner's Avatar
I would have her drive it once a week, and have her engage 4wd once a month. Use 4 hi, for a bit, and then 4 lo. Lubes everything in the front axle, and tcase.
The ethanol in gas can and will eat holes in your fuel lines. Being a new TJ you won't have as much problem, but my old YJ I would drive only to wheel, and using crap gas from shell that uses ethanol ate my lines. I would only use chevron, or whatever stations use 100% gas while you are away.
Thank you for your service!
--Turner--
2006 Jeep TJ
1982 Toyota Pickup 20r/22r Hybrid, 5.29s, Lockrite frt/spool rear, Longfields, Hysteer, discs, armor, dents, smiles.
1970 Ford Bronco302, dana 30, 9", 3 on the tree, show stopper.
Turner is offline
post #20 of 27 Old 12-30-2009, 10:51 AM Thread Starter
Blackhorse6
Blackhorse6's Avatar
Thanks Everyone!
This Forum never fails to disappoint, thanks for the advice, I was thinking that 1/week was the way to go. Wanted to re-enforce that she needed to get it moving not just idling.
Blackhorse6 is offline
post #21 of 27 Old 12-30-2009, 11:06 AM
Kinless
If anything like my wife. Every time its left unattended she will take off in it.
Kinless is offline
post #22 of 27 Old 12-30-2009, 11:09 AM
silvershark
i let my old ford idle once a month for 10 + years and drove it may be 5 times... fords are pretty tough though.
silvershark is offline
post #23 of 27 Old 12-30-2009, 11:24 AM
kuebelwagen
kuebelwagen's Avatar
Thanks for Our freedom, be safe!
In love with, Suki.
Pain is weakness leaving the body.
2004 Rubicon
1995 Cherokee
kuebelwagen is offline
post #24 of 27 Old 12-30-2009, 02:55 PM
BlueFlame
BlueFlame's Avatar
Originally Posted by Netpackrat View Post
The engine may not come up to full temperature simply idling, which is necessary to burn off the condensation that builds up in the engine while it is sitting, and also the oil pump isn't flowing as much volume at idle, so extended idling isn't necessarily a good idea in any event. Also, even if the engine reaches full temp and the oil flow to the interals is adequate, leaving the vehicle sitting idling does nothing for the lubrication of the other drivetrain components.
Great replies!
One more thing - most of the above will contribute to drastically reduced life of the catalytic converters.
BlueFlame is offline
post #25 of 27 Old 12-30-2009, 03:24 PM
Mud-Hunter
I bought a manual for this very reason and I WRECKED the damn thing last weekend. Oh Why me!?
I would just have her start it up until warmed up and once around the block and RIGHT back to bed.
Mud-Hunter is offline
post #26 of 27 Old 12-30-2009, 04:35 PM
Scotch740
Scotch740's Avatar
You know the whole drive train is spinning whether your in 4wd or not, right?
No need to put it in 4wd to lube things unless your have locking hubs, and in taht case you just lock them to get things lubed.
Scotch740 is offline
post #27 of 27 Old 12-30-2009, 04:41 PM
GreenZZ
Thank you for your explanation. I was wondering myself
GreenZZ is offline
wife said i can get a jeep skiformance TJ Wrangler Technical Forum 119 12-01-2013 10:09 AM
Which Jeep for my Wife? mickmeister Wrangler General Discussion 7 03-24-2009 09:58 AM
so i got my wife a new jeep. cmyjeep JK Wrangler Technical Forum 18 05-28-2008 09:28 PM
Wife wants to drive my TJ? mytjtoy TJ Wrangler Technical Forum 27 11-29-2005 10:12 PM
Look what my wife did with my JEEP!!! julietkilo TJ Wrangler Technical Forum 10 08-05-2004 09:09 AM
