How much Negative Offset - JeepForum.com
 4Likes
  • 1 Post By TheBoogieman
  • 1 Post By grogie
  • 1 Post By Mousejockey
  • 1 Post By Wheelin98TJ
post #1 of 10 Old 07-07-2020, 10:39 PM Thread Starter
BouJee'
I've searched the forum and can't find the answer to what I feel is a simple question...
I want a little wider Track Width. As far as Knuckles and Bearings are concerned, how much Negative Offset is okay to run on 12.5" wide tires?
Please don't worry about my lift or tires or back spacing or fenders or my state laws, etc. Just want to know as far as Knuckles and Bearings are concerned...how much Negative Offset on 12.5" wide tires is Okay? Thank You.
Sent from my SM-N970U using Tapatalk
BouJee' is offline
post #2 of 10 Old 07-07-2020, 10:45 PM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Forget offset and think backspacing. 3.75-4.5."
Richisinyoface likes this.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
2003' Rubicon/Zone 4.25" combo lift with Rancho RS5000X shocks/ Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
TheBoogieman is offline
post #3 of 10 Old 07-08-2020, 12:48 AM Thread Starter
BouJee'
This is 4.25" back spacing. So what do I need? Wider wheels/tires? Wider axle assembly? Your Track Width is where I'd like to be.
BouJee' is offline
post #4 of 10 Old 07-08-2020, 04:04 AM
TheBoogieman
Mine are 4" backspacing, but I have 10" wide wheels.
post #5 of 10 Old 07-08-2020, 07:50 AM
grogie
I Like to Camp
grogie's Avatar
You can find less backspacing. I use to have 15x8" wheels with 3.25" backspacing. Shown here, these are 11.5" wide tires.
BouJee' likes this.
Red Jeep Club #345
'06 TJ Sport -
'04 KJ Limited - Sold
'13 Off-Road Trailer -
'19 Tacoma TRD OR
"Civilization is what old men salvage
from the onslaught of young idealists. Don Colacho
grogie is offline
post #6 of 10 Old 07-09-2020, 08:31 AM
Mousejockey
The farther out you go from the factory location, the more stress you put on the hub bearings
Many times I hear people say that the hub bearings on TJ's are a 'weak point', you never hear the same people say how much offset or how large their tires are.
I seem to change my bearings every year, 35-13.5/15 on 10" wheels and 3.75 offset and running them over boulders all the time I expect it.
Run what ya want but expect what will happen
BouJee' likes this.
Mousejockey is offline
post #7 of 10 Old 07-10-2020, 08:54 AM
2jhanna
As mouse stated above, the further out you go, the more stress. Unless you go with wider axles, which is a whole other topic.
Why not just try a set of wheel spacers. Cheapest, easiest way to go, and see where that gets you.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #8 of 10 Old 07-10-2020, 11:17 AM
TheBoogieman
Bearings are pretty cheap. I buy Detroit axle and get free ones if they fail within 10 years. Don't ask, don't tell, goes for warranty info too.
post #9 of 10 Old 07-10-2020, 01:12 PM Thread Starter
BouJee'
Well that's the plan. Apparently I can only space 1/2" to be at the coveted 3.75" which doesn't seem like a big enough difference. May just jump up to an inch and deal with bearings.
BouJee' is offline
post #10 of 10 Old 07-10-2020, 01:54 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
2020 J-Series Truck
1/2" spacers are the type that do not bolt on. I wouldn't use those.
1.25" spacers will put you at the equivalent of 3" backspacing. That would be fine. You'll end up looking very similar to grogie's red TJ posted above except 1/4" wider on each side.
Or dump your 8" wide wheels and get 10" wide. 8" wide wheels with 4" backspacing vs 10" wide wheels with 4" backspacing, the 10" wheels stick out 2" further.
Wheelin98TJ is offline
