Page 1 of 2 | 1 | 2 |
LinkBack | Thread Tools |
how much antifreeze/coolant
My Jeep has water only in radiator (it IS arizona) but i will be taking it up into the mountains and it gets below freeezin up there. So when i drain the water how much new 50/50 will i need to put in?
Sponsored Links | |||
If you buy premixed coolant, you need to fill it full of premix (the name 50/50 comes from the fact that its premixed 50% water, 50% coolant) if you buy concentrated coolant, i like to go 60% coolant 40% water here in colorado. i wouldnt go much more either way though.
"No beer and no t.v. make Jack something something..."
Colorado Jeep Club #145!!
Black Jeep Society
Administrator
Your cooling system holds 10.5 quarts of coolant, that type of information can be found in the forum's FAQ at the top of TJ Tech forum's main page.
But even in Arizona, never run just plain water in your cooling system. Coolant contains a lubricant the water pump requires as well as antirust/anticorrosive additives that keep your cooling system from rusting/corroding out. And never run regular tap water either, use distilled. Tap water is loaded with dissolved mineral content, especially there in Arizona, which will clog up your radiator with hard water deposits.
After choosing the percentage mix that you want you can buy a pretty inexpensive tool that will tell you to what cold temperature your radiator is prep'ed to handle. Any of these should do:Amazon.com: antifreeze testers: Automotive
Bill J.
'98 Wrangler, 4.0, Auto, Hard/Soft Tops, Dana 44's, PIAA Fog's...
Originally Posted by Jerry Bransford
View Post
2000 Solar Yellow TJ
2000 Ford F250 Super Duty
2006 Volvo S40
1997 Arctic Cat ZRT 600
Jerry, what is your opinion of "softened" water and "reverse osmosis" water ?
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
you want distilled (less minerals to cause corrosion)
Originally Posted by 2jhanna
View Post
'Softened' water still has the 'bonus extras' in it, plus salt! Bad stuff to put in your engine or your battery either.
I only got 2 Gallons in my Radiator before it started to overflow. let the JEEP run for 15 minutes and took the Cap off again and still full. Jerry, you estimated 10.5 quarts but it barely took 8....
also I tried putting the heat on while it was running and it went ftom warm to cool air blowing.
Originally Posted by BlazinJack
View Post
Like Jerry said, not a good idea to run just water. Also while you have it all drained I would flush the system. This coming summer when it is warm again that's what I will be doing because I don't think it has ever been done
This post/info=my opinion
Originally Posted by freeskier93
View Post
Especially this winter in Colorado...
do your cooling system and battery right if you're coming to the moutains. if you don't, you'll only make that mistake once.
Useful Write-Ups:
Fabrication & Build:
Funny:
R.I.P. Knuckelhead
Originally Posted by Unlimited04
View Post
x2...-2*F this morning, with -36*F windchill
Gone but not forgotten.
^I living in VT and I'm planning to impliment a dual battery system , I like the idea of a backup (plus I like to run a power drill off the inverter due to a lack of out side power).
For the coolant I not use anything other than distilled water it is as close to pure H2O as you can get and then add then mix in the recommended dilution of coolant, maybe a hair over.
Atheist Jeep Club Member #2
Doctor Who has died 13 times, is on his 14th regeneration and has a time machine, beat that Jesus.
Originally Posted by timberwolf0122
View Post
View Post
Previous Thread
Next Thread
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Similar Threads | ||||
Thread | Thread Starter | Jeep Forums | Replies | Last Post |
Antifreeze/Coolant Smell but no leak... | greta | TJ Wrangler Technical Forum | 8 | 04-28-2010 05:28 PM |
huge coolant leak/ creamy coolant?? | 11Bgixx | TJ Wrangler Technical Forum | 17 | 01-11-2010 10:24 AM |
1997 TJ - Recommended Antifreeze/Coolant Type? | steevireno | TJ Wrangler Technical Forum | 2 | 02-24-2008 09:42 AM |
Cooling System knowledge - Coolant Antifreeze Overheating Thermostat Troubleshooting | dragginwagon406 | TJ Wrangler Technical Forum | 8 | 03-31-2007 03:03 AM |
how much antifreeze | mjeselskis | YJ Wrangler Technical Forum | 13 | 01-18-2007 06:24 PM |
Posting Rules | |
