How the Metalcloak Duroflex bushing stacks up - Page 70 - JeepForum.com
 2Likes
post #1036 of 1044 Old 07-19-2016, 12:00 PM
grininmonkey
grininmonkey's Avatar
Originally Posted by Shadowline View Post
... also look into Tray Mountain and Charlies Creek over in Georgia.
Looks like some fun ridding... that area is 5 hours away for me... got to look into some spots to park the RV and make a weekend of it sometime.
grininmonkey is offline
post #1037 of 1044 Old 07-20-2016, 05:33 AM
platinum5.9
platinum5.9's Avatar
2003 WJ
Does anyone know if I can replace the Currie Johnny joints on my Clayton longarms with these Metalcloak bushings?
03 Grand/WJ-White 4.7HO/QD/242HD Clayton 6" LA,5100,Clayton skid,Custom Rockers,JK OME SS,17"Rock Monsters 33"Interco Irok ND,Muffler delete/MF cats,SOLID D30/BTF D44a,Fawkes,Projectors/HID
platinum5.9 is offline
post #1038 of 1044 Old 07-20-2016, 05:59 AM
grininmonkey
If the joints are actually "Johnny Joints" then the following can be used
http://www.metalcloak.com/2-5-8-ODx2...ade-p/7351.htm
They have other options as well.
http://www.metalcloak.com/Jeep-Suspe...arts-s/235.htm
post #1039 of 1044 Old 07-20-2016, 06:31 PM
platinum5.9
2003 WJ
Look to be "Johnny joints" to me
post #1040 of 1044 Old 03-21-2017, 08:46 AM
ROWlegend
ROWlegend's Avatar
Awesome thread and comparison
Imped, thanks for such a geat post! This thread convinced me to join JeepForum. Many other great contributions by members thrown into the mix.
Wine em, dine em, pipeline em!
ROWlegend is offline
post #1041 of 1044 Old 03-21-2017, 10:16 AM
Scarfist
I have been running the Metalcloak CAs for almost 2 years. After 2 Rubicon Trips and multiple other Sierra trails, they are holding up great.
I am considering switching over to Ori Struts for some great down travel in a LCG jeep. That ride could be so smooth.
I'm too old to play with Lego's, so I got a Jeep. 97 TJ club member
Scarfist is offline
post #1042 of 1044 Old 03-21-2017, 10:21 AM
biffgnar
biffgnar's Avatar
Unless going to full width axles good luck with the packaging. Not worth the work. Quality shocks with extended/outboarded towers will be less work, cheaper and perform just as well. And IMO lots of down travel is way overrated. If ORIs were so great you'd see them used often in competition contexts and the reality is you almost never see them used in that context.
biffgnar is offline
post #1043 of 1044 Old 09-28-2018, 01:52 PM
btn
btn's Avatar
I just pulled mine out to check on them when I was adjusting the pinion angle yesterday. They had been in around 5 years and at least 50k miles. The rubber bushings themselves looked like new, however there was no grease left on the bushing friction surfaces. I’m regreasing them and reinstalling, but I’m adding some homemade “seals” in the form of 2” flexible washers on either side of the joint to try to protect the joint from dirt and grease washout. I’ll have to give it several years and see how well the grease stays in place.
2000 TJ, 4.0L, 4" suspension lift, 35s, rear D44 and front HP30 both with ARBs. AX15, 4:1 T-case.
btn is offline
post #1044 of 1044 Old 09-28-2018, 02:08 PM
freeskier93
Originally Posted by btn View Post
I just pulled mine out to check on them when I was adjusting the pinion angle yesterday. They had been in around 5 years and at least 50k miles. The rubber bushings themselves looked like new, however there was no grease left on the bushing friction surfaces. Iím regreasing them and reinstalling, but Iím adding some homemade ďsealsĒ in the form of 2Ē flexible washers on either side of the joint to try to protect the joint from dirt and grease washout. Iíll have to give it several years and see how well the grease stays in place.
No need to do this if you are using the supplied grease, which is Teflon based. It isn't necessarily washing out, the grease is suppose to dry and leave a Teflon film.
freeskier93 is offline
control arms , duroflex
