How to identify my steering control arm/draglink - JeepForum.com
post #1 of 7 Old 07-10-2020, 08:53 AM Thread Starter
pipeburn
Hello jeepsters ,i am doing a 97 jeep tj restoration and upon doing the tear down on the front steering i have noticed along with the 6" of lift it has a very heavy duty steering arm and drag link, the arm itself is 1.500 in dia and has been painted a few times and i do not see and type of markings on the control arm,as for the drag link there are numbers on the adjustable left hand 1 /1/8th thread [i beleive?] letters and numbers are[k h 322] ,i was able to get the drag link tie rod to turn on one end and it needs a new tie rod can i buy just the tie rod or do i haveto buy the whole assembly threaded end with tie rod??. any help would be appreciated ,thank you.
pipeburn is offline
post #2 of 7 Old 07-12-2020, 09:58 AM
Ben
Ben's Avatar
Any way you could post some more pictures of the rest of the components?
That looks like Rough Country but I really have no idea.
You might be able to find a replacement TRE here: http://www.partsmike.com/index.php/c...e-rod-draglink
Ben is offline
post #3 of 7 Old 07-12-2020, 11:42 AM
Duck Doctor
Could be a custom steering setup. All three of my rigs have steering built using DOM and one-ton Chevy rod ends. Cheap to build your own steering.
Duck Doctor is offline
post #4 of 7 Old 07-12-2020, 05:41 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Here you go.
Jerry Bransford is online now
post #5 of 7 Old 07-16-2020, 05:35 PM Thread Starter
pipeburn
thread size
Yes jerry i believe that may be the case as they used d.o.m tubing ,it looks like the ends were welded making me think if it was bought they can thread the ends to what the customer needed or if it was made they threaded it then welded on the end, i found the thread to be a metric thread m22 x 1.5 and i was also directed from another jeepster a web site to try and find the heims, thanks again jerry.
pipeburn is offline
post #6 of 7 Old 07-16-2020, 09:48 PM Thread Starter
pipeburn
it seems like pulling teeth to upload a pic, i have tried several times, idk
pipeburn is offline
post #7 of 7 Old 07-17-2020, 07:10 AM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
I think you need at least 10 posts to upload a picture. Your are now at 10, so you should be able to now. Give it another shot.
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
