How To Disconnect Hard Top Wire Harness? - JeepForum.com
post #1 of 16 Old 06-21-2007, 07:50 PM Thread Starter
Tommy R
Tommy R's Avatar
Of course I searched, but got the beloved blank white screen again. Can anyone explain how in the heck to disconnect the wire harness to the rear of the hardtop, please?
Thanks!
Tommy
2001 Wrangler stretched 99" WB, ARBs, alloys, ORIs, 4.88s, 37" Nittos
Tommy R is offline
post #2 of 16 Old 06-21-2007, 07:57 PM
Crashnburn80
Crashnburn80's Avatar
There is a red little 'switch'. It slides to the side to release the harness. Royal PITA. Now when I put my hardtop back on I do not click the switch to 'lock' it on.
| 1.25" BL |
| Riddler diff covers |
| 33" MTRs | Warn M8000 |
and much more...
Crashnburn80 is offline
post #3 of 16 Old 06-21-2007, 08:04 PM Thread Starter
Tommy R
Tommy R's Avatar
Thanks. I've looked and didn't see anything red. Some small grey tabs among the wires, but that's it. Where is this switch?
Tommy
Tommy R is offline
post #4 of 16 Old 06-21-2007, 08:06 PM
Crashnburn80
Tommy
Yours might be grey. I have an 04 vs your 01, so they could of changed it because of frusterated people like yourself. Although when I took mine off for the first time it didn't help that it was red, I still didn't get it and it was still a PITA.
The switch is on the actual plug.
| 1.25" BL |
and much more...
post #5 of 16 Old 06-21-2007, 08:08 PM Thread Starter
Tommy R
Tommy R's Avatar
So they need to be slid to the side before the plug can come out?
Tommy R is offline
post #6 of 16 Old 06-21-2007, 08:13 PM Thread Starter
Tommy R
Tommy R's Avatar
I'm lost! I pulled out the three grey pins, but that's all they were.....pins. Obviously I still can't remove the plug. Is this red thing on the side, top, bottom, driver's side, rear, etc? In what direction does it slide?
Thanks,
Tommy
Tommy R is offline
post #7 of 16 Old 06-21-2007, 08:27 PM
bman9089
bman9089's Avatar
Thanks,
Tommy
take a pic of it.
"The American Republic will endure, until politicians realize they can bribe the people with their own money." -- Alexis de Tocqueville
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it” -- Mark Twain
Romans 12:5 | 1 Peter 3:15 | Matthew 9:37-38
bman9089 is offline
post #8 of 16 Old 06-21-2007, 08:35 PM Thread Starter
Tommy R
Tommy R's Avatar
Waiting on the battery to charge.
Tommy R is offline
post #9 of 16 Old 06-21-2007, 08:52 PM Thread Starter
Tommy R
Tommy R's Avatar
Okay, here's the best I could do....
Tommy R is offline
post #10 of 16 Old 06-21-2007, 09:09 PM
john NC
john NC's Avatar
my switch was way up in the housing the first time i took my hardtop off. i had to reach up into it w/ a pair of needle nose pliers to get it, made a click when i got it and then the thing just came right off
and of course it didn't get locked when i put it back on, if i need it to hold better i'll just wrap it in some duct tape
john NC is offline
post #11 of 16 Old 06-21-2007, 09:11 PM Thread Starter
Tommy R
Tommy R's Avatar
So where would I look for it? I can't see it anywhere... Do you mean it's recessed within the plug where the wires go into it? I just don't see where this elusive switch/lever thing is!
Tommy R is offline
post #12 of 16 Old 06-21-2007, 09:12 PM
john NC
john NC's Avatar
if i remember correctly man, it was towards the top of the piece in the picture w/ the wires going into it
it was a little while ago, if you still haven't gotten it by tomorrow i'll go outside and look for you
john NC is offline
post #13 of 16 Old 06-21-2007, 09:15 PM
jeepnaked98
idk if yours is any different than mine but on my 98 i just had to depress the plastic in and under the raised part of it and pull. at first i couldnt get it out for the life of me and thought i was doin it wrong but it just needs to be pulled really hard. put some muscle into it and it should come right out.
jeepnaked98 is offline
post #14 of 16 Old 06-21-2007, 09:18 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
just pull on it
My builds:
and
or follow us on
spyder6 is offline
post #15 of 16 Old 06-21-2007, 09:21 PM
john NC
john NC's Avatar
give it a good yank, i thought mine was about to come apart at first but it's fine
john NC is offline
ABS ECU & Wire Harness on Non ABS YJ MooCowMan YJ Wrangler Technical Forum 1 11-04-2009 05:49 AM
Door wiring harness disconnect kobecoyote JK Wrangler Technical Forum 4 06-06-2009 09:09 AM
battery wire harness green wire? brinoff YJ Wrangler Technical Forum 4 03-07-2009 04:25 PM
Disconnect Wiring Harness- Hard Top removal mfdevine JK Wrangler Technical Forum 4 04-14-2008 09:53 AM
removing hard top wire harness sbcvulcan YJ Wrangler Technical Forum 3 08-01-2004 02:11 PM
