how to change speedo calibration on 99 wrangler - JeepForum.com
 1Likes
  • 1 Post By TheBoogieman
post #1 of 14 Old 07-22-2010, 11:59 AM Thread Starter
dmw319
I did a search and read a few posts, none of which answered my question, so here it is..
My 99 wrangler has 33" bfgs and a 3.5" body/suspension lift. stock gears and axles, etc (i think, just bought the car). While driving next to my wifes car, the speedo reads about 10mph off (driving at about 65 mph on highway the speedo read only 55). What is the best way to fix this problem? Any write-ups or links would be very helpful. thanks!
dmw319 is offline
post #2 of 14 Old 07-22-2010, 12:01 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
You'll need to know your axle ratio and once you figure that out, go to Changing Your Jeep Speedometer Gear and click on the chart. With your axle ratio and tire size, the chart will tell you what speedometer gear tooth count to use to recalibrate your speedometer. That webpage will show you how to swap the speedometer gear which can be done in 5-10 minutes with nothing more than a 1/2" wrench.
Jerry Bransford is offline
post #3 of 14 Old 07-22-2010, 12:02 PM
LuckRider
LuckRider's Avatar
Either a new speedo gear or a digital speedo box. Fairly common thing because the final drive ratio is now off.
Edit: Jerry posted while I did. He explained the speedo gear route. With the electronic box (like the dakota digital) you can keep changing it.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #4 of 14 Old 07-22-2010, 12:02 PM
mdm
Farm Wheeler
'98 TJ Speedometer Gear
TJ speedo gear chart : Raingler.com
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #5 of 14 Old 07-22-2010, 12:04 PM Thread Starter
dmw319
how do i determine the axle ratio?
dmw319 is offline
post #6 of 14 Old 07-22-2010, 12:11 PM
LuckRider
LuckRider's Avatar
There are a few ways. If you are positive it is stock, you can read the little metal tag on the diff. The other way is to jack up the rear end and count how many rotations the drive shaft makes for every 1 rotation the tire makes. The tag on the diff should be correct though. It should look like this:
Edit: this axle is 4.63 gear ratio as indicated by 4_63 written on the left side of the tag.
Support Our Troops!
JFI Member #7:
post #7 of 14 Old 07-22-2010, 12:17 PM Thread Starter
dmw319
thanks ill check that if i can still read it haha.
dmw319 is offline
post #8 of 14 Old 07-22-2010, 01:03 PM
Knuckelhead
R.I.P. Knuckelhead
Knuckelhead's Avatar
You need a speedometer gear with 3 less teeth, 1 tooth = 3 mph...
Gone but not forgotten.
Knuckelhead is offline
post #9 of 14 Old 07-22-2010, 01:05 PM Thread Starter
dmw319
best place to buy the speedo gears?
99 wrangler TJ - 2.5L I4, intense blue, 33" bfgs, detroit lockers, 3.5" lift, PIAA lights
my blog (music, the church, life, etc)
dmw319 is offline
post #10 of 14 Old 07-22-2010, 09:13 PM Thread Starter
dmw319
thanks guys! ordering one from quadratec now. i had 4.11 gears and 33" tires, so i got a 36.
dmw319 is offline
post #11 of 14 Old 07-29-2010, 11:23 AM Thread Starter
dmw319
BUMP. I put the new speedo gear in last night and the speedometer read EXACTLY correct with the speed on my GPS. Thanks!
Here is the weird thing.. there was a 41 in there when I replaced it with a 36. Strange...?
dmw319 is offline
post #12 of 14 Old 08-02-2010, 10:41 PM
onestringer
Excellent info, I have been working with a local shop for a month on this very issue. After reading the instructions I just ordered the correct gear and will install myself.
Scott
onestringer is offline
post #13 of 14 Old 12-05-2017, 08:43 AM
eddiefast
Resurrecting old thread because TJ knowledge is timeless. Is there a real need to change speedometer gearing if you have a manual transmission? I am running 33s and 10% seems accurate as the delta from actual speed and acceptable IF I am not overlooking other consequences.
eddiefast is offline
post #14 of 14 Old 12-05-2017, 01:58 PM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
No need to change it if you don't mind the speedometer and odometer being off.
eddiefast likes this.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4" coils with 1" spacers up front/Rancho shocks/5.13 gears-35" MTZs/Black Magic brakes.
99' XJ /4.0L-AW4/ 5.5" lift / Rancho RS5000X shocks/33" DC Extreme country MTs. Jeep #18
TheBoogieman is offline
speedo gear , replace , tj , wrangler
09 Wrangler 33" tire & speedo calibration kevinc513 JK Wrangler Technical Forum 11 01-14-2009 06:42 AM
97 TJ Speedo calibration MillerTimeTJ TJ Wrangler Technical Forum 1 05-08-2007 07:11 AM
Speedo Calibration Gav'spurplez TJ Wrangler Technical Forum 20 11-30-2006 09:54 AM
Speedo calibration? Jeepster Tim TJ Wrangler Technical Forum 14 06-28-2005 09:12 AM
speedo calibration Dr Gutiemouth TJ Wrangler Technical Forum 4 05-22-2004 01:10 PM
