How can I slightly lift my rear end to cure stance issue?? - JeepForum.com
post #1 of 29 Old 08-29-2015, 02:00 PM Thread Starter
gsindela
I have an '03 TJ X with 32" BFG AT KO2s, a 2" spacer lift, and Rancho RS9000XLs.
Here is my issue: the front end sits slightly higher than the rear. The stance simply looks off. I want to cure this, but am not sure the best way to do so.
Looking to you guys for suggestions. Thanks in advance!
gsindela is offline
post #2 of 29 Old 08-29-2015, 02:43 PM
JBTJ
JBTJ's Avatar
Remove the 2" spacer lift in front and replace with 1.5". Or replace rear springs with 3" lift springs.
JBTJ is offline
post #3 of 29 Old 08-29-2015, 03:16 PM Thread Starter
gsindela
My Rancho's are spec'd for 2" lift. If I go up to 3" springs in the rear, will my shocks be OK??
gsindela is offline
post #4 of 29 Old 08-29-2015, 03:20 PM
JBTJ
JBTJ's Avatar
Hard to say. The JEEP naturally has a slight rake to it making the front sit lower than the rear. Installing a 2" lift should have kept it that way. I installed a 1" spacer in front because I wanted my JEEP to look level.
JBTJ is offline
post #5 of 29 Old 08-29-2015, 03:25 PM
JBTJ
JBTJ's Avatar
You could also add a winch to the front to bring it down and make it "look" cooler.
JBTJ is offline
post #6 of 29 Old 08-29-2015, 04:14 PM
J03_TJ
J03_TJ's Avatar
Pull the backseat?
J03_TJ is offline
post #7 of 29 Old 08-29-2015, 04:30 PM Thread Starter
gsindela
no need for a winch, but i do need the backseat for the kiddos! looking at OME 10mm trim spacer for the rear unless I come up with a better idea. thanks to everyone for the information.
gsindela is offline
post #8 of 29 Old 08-29-2015, 04:53 PM
VARIABLE9
That's a lot of work for 10mm - if you are disassembling to that point just replace the springs. It will be a better Jeep for it.
VARIABLE9 is offline
post #9 of 29 Old 08-30-2015, 07:41 AM Thread Starter
gsindela
Yes, I think you may be right. Wasn't wanting to spend the $$ on new springs, but I just may do so.
gsindela is offline
post #10 of 29 Old 08-30-2015, 08:11 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
You need to figure out why your Jeep sits that way first. They should sit 1.5" higher in the rear. Did you install the lift? Were the rear spring isolators removed? Is there a dead body in the back?
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4" coils with 1" spacers up front/Rancho shocks/5.13 gears-35" MTZs/Black Magic brakes. ***SOLD*** for Covid-19 pandemic rent money. :(
99' XJ /4.0L-AW4/ 5.5" lift / Rancho RS5000X shocks/33" DC Extreme country MTs. Jeep #18
TheBoogieman is offline
post #11 of 29 Old 08-30-2015, 08:16 AM
rda616
rda616's Avatar
You can buy BDS 2" rear springs for about $100. They have a higher spring rate than the stock rear springs and will support more weight.
What are the extended and collapsed lengths of your shocks?
rda616 is offline
post #12 of 29 Old 08-30-2015, 08:18 AM
rda616
rda616's Avatar
Those damn dead bodies get you every time. Rofl
rda616 is offline
post #13 of 29 Old 08-30-2015, 08:21 AM
Ironhead
Ironhead's Avatar
agreed, something else is going on. I run 3" fronts and 2" rears and still have a slight rake due to the factory design
Ironhead is offline
post #14 of 29 Old 08-30-2015, 08:31 AM
TheBoogieman
post #15 of 29 Old 08-30-2015, 08:33 AM
TheBoogieman
So do I. 5" front/4" rear.
lift advice. , spacers
