A Horrible Mistake of a Lift Kit - Page 3 - JeepForum.com
 61Likes
post #31 of 150 Old 12-12-2017, 06:50 AM
toximus
Originally Posted by CaptainGatorade View Post
Originally Posted by toximus View Post
That might work. OP will need to make sure he works with measurements from his year as skid positions changed slightly, didn't they?
My unique circumstances probably allow this to work better than you might expect. I just need some decent dimensioned drawings of the mounts and their locations on the frame and axles. We have a plasma table at work and I do a large amount of drafting work. We have a CNC break, and I have machinist friends. The means are there. I will just need a good Samaritan to help me out with the drawings.
Sent from my SM-G892A using Tapatalk
What are you wanting to do with your Jeep? That may determine what you want to build.
Building the right way for 37s.
toximus is offline
post #32 of 150 Old 12-12-2017, 07:06 AM Thread Starter
CaptainGatorade
I don't need any serious off road capability. I'll mostly just be on old gravel roads, a few fields, ect. I wanted to run 35's, but from the sound of it, that's a lot more expensive than I'd like to deal with. I was thinking in my initial post it would be similar to a dodge/chevy truck on 35's, but a bit of research later, I'm finding that this is not the case.
I wonder if the most cost effective option may be to find a rollover wrecked TJ and starting swapping parts. Sell what I don't need, scrap some of the trash I've got.
CaptainGatorade is offline
post #33 of 150 Old 12-12-2017, 07:09 AM
jjvw
jjvw's Avatar
At least then, you would have a template for what shouldn't be there and for what should. Honestly, a frame and axle swap makes the most sense. Skip trying to undo what has been done.
Sent from my SM-G950U using Tapatalk
2003 Rubicon
jjvw is offline
post #34 of 150 Old 12-12-2017, 07:36 AM
Shark_13
Make your cousin give you your money back, go buy a stock Wrangler.
Shark_13 is offline
post #35 of 150 Old 12-12-2017, 08:35 AM
rficken42
rficken42's Avatar
i think buying a new used frame and a set of axles would be more cost effective then returning that to stock. you will probably be chasing issues forever if something isn't aligned when re-welding or something was installed on it poorly.
99TJ 5.2V8 ax15 2.5lift dana30/44 Lockers 410s 35s AtlasII bellyup skid & winch
rficken42 is offline
post #36 of 150 Old 12-12-2017, 08:48 AM
toximus
Depending on where you're at (or if you want to freight them) I have a Dana 44 and 30 set I'll be selling. Very good shape structurally, but rusty. You might be just as happy with a Dana 35 rear though.
toximus is offline
post #37 of 150 Old 12-12-2017, 09:05 AM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
I think it depends how much you are into it for, and how much you are willing to spend.
Yes, it has a lot of extra crap, but that frame looks low mile and rust free, no?
Many TJ owners would kill to have that as a starting point compared to what they currently have.
Not finding/ swapping a frame saves a good ton of dough that can be put towards fixing the rest of the suspension
Hoss
Good judgement comes from experience; experience comes from bad judgement
JoonHoss is offline
post #38 of 150 Old 12-12-2017, 09:08 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Measurements for the frame from the Factory Service Manual are below.
Unfortunately the FSM does not provide measurements for the axle brackets.
Wheelin98TJ is offline
post #39 of 150 Old 12-12-2017, 09:12 AM Thread Starter
CaptainGatorade
Hoss
Yes, the frame is rust free and has 35k miles on it. I want to stay under $15k total cost ($12k optimal). I paid $7k for it. The wheels and tires on it should bring $1k or so. The rest is probably trash. I have a couple of Dirt Logic shocks left over from my truck lift that I might be able to use.
post #40 of 150 Old 12-12-2017, 09:14 AM Thread Starter
CaptainGatorade
Attachment 3560394
Attachment 3560402
Thank you! I wonder if there are any detailed drawings of the brackets themselves. I'm sure it would be cheaper to fab them vs purchasing replacements
post #41 of 150 Old 12-12-2017, 09:20 AM Thread Starter
CaptainGatorade
I'm in MO. I kinda doubt it would be the most economical option to ship those to me, but thank you!
post #42 of 150 Old 12-12-2017, 09:23 AM
zackcj7
Even though i'm not really a fan of long arm kits on a TJ, that may be an easier route than trying to cut off that mess and put the factory type mounts back in. If it were me I would probably cut all that crap off and toss it. Then i'd pick up a XJ high pinion 30 front and Explorer 8.8 rear from the junk yard. By some kind of long arm lift that doesn't require the factory short arm frame mounts and start from there.
zackcj7 is offline
post #43 of 150 Old 12-12-2017, 09:23 AM
Wheelin98TJ
JEEP FREAK
Originally Posted by Mattific View Post
.....and the “track bar” doesn’t appear to be connected to the frame at all....
post #44 of 150 Old 12-12-2017, 09:26 AM Thread Starter
CaptainGatorade
Do you know of any in-depth write ups for this route?
Thanks!
post #45 of 150 Old 12-12-2017, 09:28 AM
danb303
danb303's Avatar
https://chattanooga.craigslist.org/p...413951175.html
If you could find something like this and get the frame and axles.
2006 LJR Auto. 35" tires, 538 gears, IRO 4"lift. Tom Woods! JKS TB, Rancho 5000x, Currie Correctlync
danb303 is offline
