Hood wont close evenly 02 TJ - JeepForum.com
post #1 of 5 Old 06-02-2019, 05:34 PM Thread Starter
HeyDontSlip02
Bought my TJ as a fixer up a few years was in a small front end collision. Swapped in a new frame, suspension and body lift, only thing that isnt new underneath is the front driveshaft. But I always have had the issue where the hood will not close correctly.
Pics:
I have tried 2 different hoods and sets of latches with no luck. Could the grille be the problem? Fenders maybe?
HeyDontSlip02 is offline
post #2 of 5 Old 06-02-2019, 05:56 PM
cmarshand1
I canít see the picture says Not authorized but either way had same issue how do you change up different shams under the hinges. After I got it close enough I flexed the hood a little. After that going to go
Sent from my iPhone using Tapatalk
cmarshand1 is offline
post #3 of 5 Old 06-02-2019, 05:58 PM
cmarshand1
Itís finally letting me see the pictures looks like the same thing I had. Need to loosen the hinges adjust the shims accordingly set the hood down. tighten bolts. Also looks like youíre missing the rubber garments the hood lays on the fender
post #4 of 5 Old 06-04-2019, 07:00 PM
etsubchief
I had a front end collision as well on my 06 LJ, Body shop did all the work, I could tell the hood never fit quite right, After I swapped bumpers, THEN I noticed that the fenders were not even with the bumper. One sat higher than the other.
Maybe fenders are not set up even?
06' Silver Unlimited, 3" suspension lift, 33 Discoverer STT's, Black Rock Wheels
etsubchief is offline
post #5 of 5 Old 06-04-2019, 07:06 PM
biffgnar
biffgnar's Avatar
Loosen hinges and adjust.
biffgnar is offline
