Homemade Half Doors? - JeepForum.com
post #1 of 78 Old 04-03-2008, 11:15 PM Thread Starter
0blcktj6
0blcktj6's Avatar
Hey all! I ran a search but couldn't find anything on the topic. I know someone has had to try it, are there any write ups about it? I've always wanted a set of half doors but never really had the cash to buy them, something else always seemed more important, haha. So what do you guys think? I was thinking of using some wood to make them cause I don't really have the means to make them out of metal cheap. Anyone have any measurements or tips? I figure it should be decently easy. Any ideas on a latch mechanism? Any help is greatly appreciated! Thanks a lot in advance!
John
3" Currie progressives, OME Shocks, 1" BL, 1" MML, 35x12.50" KM2's, 4.88's, Detroit in rear, Vanco BBK, Currie CA's
My Build Thread:
0blcktj6 is offline
post #2 of 78 Old 04-03-2008, 11:19 PM
deltabravo
I've seen them made of wood, there's a club around my area and several of the Jeeps run them. They look pretty decent and are plywood I believe.
Here's a pic:
deltabravo is offline
post #3 of 78 Old 04-03-2008, 11:21 PM
RLD831
RLD831's Avatar
I guess the best way would be to clamp a piece of plywood to the door opening and trace it from the inside, then cut it with a jig saw. You could get a set of factory hinges pretty cheap and bolt them on. That would also allow the use of mirrors. For the latches you would either have to rig something up or buy replacement latches for half doors or soft doors.
...After rereading my description I may have to try this soon. It sounds very doable. You could even add brackets on the inside of the doors to accept uppers.
RLD831 is offline
post #4 of 78 Old 04-03-2008, 11:47 PM Thread Starter
0blcktj6
0blcktj6's Avatar
Yea it seems really easy I'm surprised not many have tried it before. I figure the hinges from the dealer probably wouldn't be that much but again they do charge 15 bucks for the rubber isolators on the tailgate so who knows haha. But yea this definitely sounds like something I'll be doing. I was thinking for the latch mechanism I could use a fence gate type mechanism similar to this
that would just clip onto the door striker. What do you guys think?
My Build Thread:
0blcktj6 is offline
post #5 of 78 Old 04-04-2008, 12:20 AM
.Jch.
.Jch.'s Avatar
huh, i've never thought about this, seems like it could be an easy weekend project.
_____
l JEEP l
OllllllllO
2006 Unlimited
Black Jeep Club V2.0 Member #2006
.Jch. is offline
post #6 of 78 Old 04-04-2008, 12:41 AM
randonlee25
Guest
If you did it in wood you could very easily wrap some fiberglass matting over it and add the resin and have a fiberglass shell over it. (seen it done to body kits before- not with wood of course)
randonlee25 is offline
post #7 of 78 Old 04-04-2008, 12:46 AM Thread Starter
0blcktj6
0blcktj6's Avatar
Hahaha I was just gonna paint them but hey this might be a cool idea. Trying to keep this fairly inexpensive. I was also wondering what might be done for an armrest or something? I could probably just fab up a pad or something that I could screw on top of the doors, who knows. Haha it's times like these where I wish I didn't go to scholl 5 hours away from my Jeep just because I'm getting really antsy and want to start trying to make these.
My Build Thread:
0blcktj6 is offline
post #8 of 78 Old 04-04-2008, 06:40 AM
Skyryder
Skyryder's Avatar
You may try to do like composite wings on homebuilt aircraft. Use "blue board" Styrofoam (sic) then resin coat a fiberglass covering, works well with wings and very strong if done right. Wont rust, warp, can be painted and modified with latches,armrest and weather strip. Just use the right resin compatible with the foam board. The door frame would be easy to shape with a rasp or knife then coat.
Skyryder
'97 Black TJ - 4 banger - 5 speed
Proud user of the "K.I.S.S." Principle.
Black Jeep Society #264
Skyryder is offline
post #9 of 78 Old 04-04-2008, 07:23 AM
FLATFENDER54
FLATFENDER54's Avatar
This is crazy..................wooden doors??? I think im gonna have to make one for the passneger side - lol (where my 3 1/2 year old son sits
the one in the pic above does not look like factory hinges to me - Any better pics? I think you could just get some round bar or even all thread and bend it 90degrees and attach that to the plywood with something and use it as the hinge
01 TJ Sahara 4"short arm/rear gas&tire
carrier bumper/front winch bumper winch/detroitEz
1954 WILLYS CJ3B (under construction)
FLATFENDER54 is offline
post #10 of 78 Old 04-04-2008, 07:27 AM
slate210
cool idea....I may just have to do that myself.
2000 TJ 4.0 5-SP 115k mi. Patriot Blue - Bone stock...for now.
1997 TJ 4.0 5-SP 134k mi. Red Jeep Club Member
- Some mods...
2006 VW Jetta TDI DSG 54k mi. BLACK Rocketchipped, boostvalve, boost gauge.
slate210 is offline
post #11 of 78 Old 04-04-2008, 07:28 AM
IIIIIlllllIlI
I've always wanted to do this. i even made a cardboard templet i probably still have laying around. maybe I'll try to finish this project this weekend
97 grn TJ
Dana 44 at both ends, 3.5" RE Lift, 33x12.5" BFG MT on 15x8" Procomp 1069s
Little stuff too
IIIIIlllllIlI is offline
post #12 of 78 Old 04-04-2008, 08:09 AM
tebriel
Guest
i bet you could end up making some out of fiberglass and selling them for cheaper, i'm surprised no one has done that yet.
-teb
tebriel is offline
post #13 of 78 Old 04-04-2008, 08:22 AM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
Cardboard and duct tape.YeeeeeeeHaaaaaaaaaaaaa.
TheBoogieman is offline
post #14 of 78 Old 04-04-2008, 09:21 AM
gily25
Bestop used to have those plastic doors...I would assume fiberglass ones would be similar. Not sure why they stopped selling them. Look for hardware for mounting the upper softop for diamondplate doors and soft top door handles, I'm sure it will work for the plywood.
http://www.quadratec.com/products/11047_02.htm
http://www.quadratec.com/products/11140_900.htm
gily25 is offline
post #15 of 78 Old 04-04-2008, 09:28 AM
Unscathed
wow... I like this.. I will be doing this project as soon as the others are done.. lol.. provided the wife lets me have my wallet back.
Best Axles and service you will find.
The owner of Alljeep.com, Wayne Hartwig will work within your budget!!! He is very informative to anyone not knowing much about axle work and will meet or beat any competitor's advertised price on any specific product delivered to your door - even if he sells at cost!
Unscathed is offline
Half doors to full steel doors - '94 body, '88 doors xponce YJ Wrangler Technical Forum 8 02-20-2010 03:29 PM
2006 half doors vs, 2007-09 half doors crashtom Wrangler General Discussion 1 06-11-2009 02:12 PM
Half price half doors. No punt intended! Nick526 JK Wrangler Technical Forum 10 05-11-2009 09:36 AM
Newer TJ Half Steel Doors?....or Bestop 2 Piece Soft Doors sweetguardian00 TJ Wrangler Technical Forum 16 02-14-2008 07:21 PM
TJ Soft half windows on YJ half steel doors? DavesMatthew YJ Wrangler Technical Forum 5 04-17-2004 11:25 PM
