high steer set up - JeepForum.com
 1Likes
  • 1 Post By pipeburn
post #1 of 6 Old 07-15-2020, 09:17 PM Thread Starter
pipeburn
high steer set up
Hello jeepsters, i recently have bought a 1997 jeep tj and i am in the 1st phase of a frame up restorasion and i am pulling off all the old suspension parts and would like to save the rugged stuff like the steering that has a high steer set up, the tie rods or heims joint are a problem one end i was able to remove it has a m22 x1.5 left and right hand thread and the dom tubing is 1 1/2 in dia,the left hand thread snapped inside with very little left in the tubing, i am staring to think is it worth replacing the tierods and were can i find the exact thread,im running 33 inch tires with 4inch lift and i am not wheeling it alot should i just go with a semi decent steering kit ,i also have the drag link with one end replacable tie rod but not the other end ,[weird] whats the sense of having one replacable but not the other, any sugestions would be great.my freind has a machine shop and will remove the remaining thread that broke its trying to find the tierods with that exact thread since most places dont offer the thread sizes it seems.
pipeburn is offline
post #2 of 6 Old 07-16-2020, 07:58 AM
Ironhead
Ironhead's Avatar
go back to the OEM design and use a ZJ v8 tie rod. as long as mounting holes havent been enlarged it is a much better setup as far as handling and will accommodate up to a 35" tire.
high steer setups can be done right but require a lot of extra work to not be a downgrade from the OEM inverted Y steering.
https://www.stu-offroad.com/steering/zjtie/tierod-1.htm
Ironhead is offline
post #3 of 6 Old 07-16-2020, 10:23 PM Thread Starter
pipeburn
Thank you very much iron head this is exactly what i was looking for and funny you send me this i was doing some research and was reading abought his exact set up ,even 1 better you gave me the part numbers to boot thank you very much !.
Ironhead likes this.
pipeburn is offline
post #4 of 6 Old 07-18-2020, 02:22 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
X2, high-steer on a TJ is the work of the devil. Dead spot in the center of the steering and bump steer. Stay with the factory geometry. '97 and newer Wranglers have a significantly upgraded steering geometry and replacing it with something else will usually create multiple steering issues.
Jerry Bransford is offline
post #5 of 6 Old 07-18-2020, 03:10 PM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
Well, unless you do it right. But it does take a bunch of work and know-how to do it right.
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
post #6 of 6 Old 07-18-2020, 05:30 PM
Jerry Bransford
Administrator
Even if done correctly I don't know of any benefits to it for a TJ built as 99% of the members here do.
