Which high steer kit for a 2006 TJ Rubicon? - JeepForum.com
 2Likes
  • 1 Post By DonnySchmidt
  • 1 Post By Ironhead
post #1 of 11 Old 06-18-2021, 09:02 AM Thread Starter
DonnySchmidt
DonnySchmidt's Avatar
Hi All,
My girlfriend wants to put a high steer kit on her 2006 Rubicon. Stock Dana 44, 4" lift on 35s. What is everyone running? Suggestions welcome. We also plan to install a Redneck Ram hydro-assist kit from West Texas Off Road. Thanks all!
DonnySchmidt is offline
post #2 of 11 Old 06-18-2021, 11:55 AM
Ironhead
Ironhead's Avatar
i suggest that you dont go to a high steer kit, they screw up the steering geometry and cause steering issues.
I mounted the driverside tie rod on the top side of the mount with a new sleeve, which raised the entire tie rod to abut the center line of the axle. note, in doing this, I needed to raise the sway bar link mounts.
the sleeve that i used is no longer an option but similar are available from a variety of sources, just google tj tie rod sleeve and many will pop up
sway bar mounts https://www.shop.blackmagicbrakes.co...K-BRACKETS.htm
Ironhead is offline
post #3 of 11 Old 06-18-2021, 12:39 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
X2, do NOT install any shape or form of a high-steer kit which just totally screws up the TJ's superb steering geometry. A high-steer on a TJ cause a dead spot in the steering and it also causes bump steer which is where the steering is bumped/forced left/right when driving over bump/dips.
The best steering upgrade for a TJ is the Rockjock (aka Currie) Currectlync HD Steering Kit. It's beefy as hell, works great, doesn't change the steering geometry, and is an easy bolt-in upgrade. By far it's the most popular steering upgrade made for the TJ. https://www.4lowparts.com/shop/curri...system-ce9701/ (currently out of stock) or get it now for $32 more from https://www.amazon.com/CURRIE-JEEP-C...4041483&sr=8-2
I have run that kit on two different TJs and I've been 100% happy with its unchanged design for over 22 years.
Jerry Bransford is offline
post #4 of 11 Old 06-18-2021, 07:24 PM
Mousejockey
I did a tie rod end flip on the drivers side, also requires raised track bar mounts
Mousejockey is offline
post #5 of 11 Old 06-19-2021, 04:10 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Tell her NO. It's that easy.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
2003' Rubicon/Zone 4.25" combo lift with Rancho RS5000X shocks/ Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
TheBoogieman is offline
post #6 of 11 Old 06-19-2021, 11:20 AM
m1jeep
m1jeep's Avatar
$560.99 + tax (free shipping).
https://jeepsarelife.com/rock-jock-c...teering-system
I just installed mine a couple of days ago and love it.
2000 Jeep Wrangler TJ
2.5L HO
m1jeep is offline
post #7 of 11 Old 06-19-2021, 04:27 PM Thread Starter
DonnySchmidt
Thanks guys. She has a Currie set up now, we just have to bend the tie-rod back lol. We will just stick with it.
Jerry Bransford likes this.
post #8 of 11 Old 06-19-2021, 09:40 PM
Jerry Bransford
Administrator
I have bent mine 2-3 times over about ten years. But it straightens with a big enough press.
John Currie specifically heat treated the tie rod so it will only bend just before something more important upstream could break. If you are ok with a tad more risk you can replace the Currie tie rod with Savvy's version which has a little more aggressive heat treatment. I did 10-11 years ago and have had no more bent tie rod.
post #9 of 11 Old 06-23-2021, 04:45 PM
RockWoRM
RockWoRM's Avatar
Hi All,
I have the Currie set up also. Have yet to bend it... Oh yeah, and I'm on 37's!
I just break other stuff instead...
On another note; I've also thought about the Ram assist. Not 100% on how it would install with the Currie, but I did come across this video where the guy had to do his own fab/mods. If anyone has another way or advice I'm sure OP and I will appreciate it.
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #10 of 11 Old 06-24-2021, 06:03 AM
Ironhead
Ironhead's Avatar
I have been eyeballing this ram assist for a while now.
https://www.shop.blackmagicbrakes.co...ACKETS-RAM.htm
07wurubi likes this.
Ironhead is offline
post #11 of 11 Old 06-25-2021, 09:43 AM Thread Starter
DonnySchmidt
I told her to quit bending it so we're all good LOLOL.
