High Angle Tie-Rod End Options - JeepForum.com
post #1 of 3 Old 05-28-2020, 11:03 PM Thread Starter
Kiwi_TJ
Hi There,
I am looking for a high angle tie-rod end for the frame mount of the panhard rod on my 1997 TJ. I have a 3" lift and it seems to be binding at extreme droop, so I was wondering if there is a common high angle tie-rod end that people commonly upgrade to?
I am keen to stick with the taper fit tie-rod end as per stock rather than a heim joint type thing.
1997 TJ Soft Top/ Half Doors
4.0 I6 with 5 Speed Manual | K&N Panel Filter | D30/D44 | 3.07 Gears | Banks Torque Tube Header
31*10.5 R15 Maxxis Trepador Radial Tyres | 2" BDS Spring Lift | Bilstein 5100 Shocks | JKS Discos | JKS Rear Swaybar Links | 100W Narva Spotlights
Kiwi_TJ is offline
post #2 of 3 Old 05-30-2020, 12:15 PM
joe_jeep
on the factory track bar or panhard rod, the tie rod end is not serviceable.
its a solid rod end to end.
i have not seen a tie rod end with extra misalignment.
most go to an adjustable track bar with a johnny joint or heim joint end.
or they go to double shear mounts and bar.
careful, most track bars dont fit well at all.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline
post #3 of 3 Old 06-24-2020, 03:14 AM Thread Starter
Kiwi_TJ
Hi Joe Jeep,
My trackbar is aftermarket with a removable tie-rod end. Not sure of the builder of this one, could be home built.
I am thinking to replace it with a GM 1-Ton version like this. They claim 30 degrees rather than 20 degrees.
https://www.ruffstuffspecialties.com/catalog/R2092.html
Does anyone have any experience with these parts?
It looks like a better option than a heim joint as it keeps the taper lock.
Kiwi_TJ is offline
