Help w/ my AC - JeepForum.com
 2Likes
post #1 of 18 Old 04-30-2021, 04:35 PM Thread Starter
davetron
davetron's Avatar
Help w/ my AC
So I have searched the net and on this forum and I found a few things it could be but I wanted to ask on here if we could narrow it down (if possible) so I am not replacing every part.
Problem: So my AC blows cold but nothing comes through on 1-3 except on the floor vents and then when I turn it to 4 it blows through the normal dash but at a low push.
I have been told to replace the Blower Control Switch panel part SW2348 https://www.autozone.com/cooling-hea...348/362052_0_0
I have also been told to replace the resistor https://www.amazon.com/gp/product/B0...6d7447b28e2c60
And... I have been told to check the vacuum lines, which I have and I do not see any cracks on it.
I wanted to ask here to see if any of you have had the similar issue and to see what you did to fix it.
Thx in advance!
davetron is offline
post #2 of 18 Old 04-30-2021, 07:50 PM Thread Starter
davetron
davetron's Avatar
so i guess its been a while since i've used my AC. It doesn't do anything until i put it on 4 and then it blows a ton out of the floor vents and barely from the dash vents.
2003 Jeep Wrangler
davetron is offline
post #3 of 18 Old 04-30-2021, 11:18 PM
mukluk
mukluk's Avatar
There's a 99% chance the cause of your fan only working on setting 4 is the blower motor resistor is bad. The blower motor gets power via its relay when the ignition is switched on, the fan is then controlled via its ground leg passing through the resistor block and HVAC panel for speeds 1-3 or just the HVAC panel for speed 4. If you have an ohmmeter you can easily test the resistor block to see if you have continuity when checking from 4 to each of the other three pins -- the most common failure will show no continuity between pin 4 and pin 3.
As for the air only blowing out of the floor vents, that could be caused by either a bad panel door actuator, broken panel door link arm, blockage inside the HVAC box, or incorrect vacuum harness connections. The best way forward would be to inspect the actuators and link arms to see if anything is broken and if things are moving in response to turning the HVAC panel mode switch.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #4 of 18 Old 05-01-2021, 03:00 AM
jtec
jtec's Avatar
2014 JK Wrangler
start by checking the blower resistor, I suspect 1,2,3 will have no resistance (open) and as mentioned 4 bypasses the resistors as HIGH has no resistor.
Do you need a wiring diagram?
jtec is offline
post #5 of 18 Old 05-01-2021, 11:20 PM Thread Starter
davetron
davetron's Avatar
I’ll replace the resistor since it’s the cheapest fix and then I’ll check back with everyone. Thank you.
TheBoogieman likes this.
2003 Jeep Wrangler
davetron is offline
post #6 of 18 Old 05-06-2021, 03:40 PM Thread Starter
davetron
davetron's Avatar
UPDATE! OK, i changed out the resistor and BAM 1,2,3 and 4 all work...
NEW PROBLEM... haha, well still the same. So now the air blows on all settings so that worked, BUT when i turn the dial 1-4 all settings come through the floor and dash vents no matter what option I choose. What should I be looking into next to fix this problem.
Thank you.
2003 Jeep Wrangler
davetron is offline
post #7 of 18 Old 05-06-2021, 04:38 PM
BlueFl.Wrangler
Supporting Member
BlueFl.Wrangler's Avatar
broken actuator arm or a vacuum issue
Diplomacy is the art of telling people to go to hell in such a way that they ask for directions
Winston Churchill
BlueFl.Wrangler is offline
post #8 of 18 Old 05-06-2021, 11:19 PM
mukluk
mukluk's Avatar
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #9 of 18 Old 05-07-2021, 05:06 PM Thread Starter
davetron
davetron's Avatar
ordered some things for the vacuum issue, im gonna diagnose that part first.
2003 Jeep Wrangler
davetron is offline
post #10 of 18 Old 05-09-2021, 07:38 AM
BlueFl.Wrangler
Supporting Member
I am thinking (could be wrong though )- looking to see if its a broken actuator arm is really fast and easy- its just a quick look & see, should be real obvious
mukluk likes this.
Winston Churchill
post #11 of 18 Old 05-09-2021, 08:56 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
2003' Rubicon/Zone 4.25" combo lift with Rancho RS5000X shocks/ Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
TheBoogieman is offline
post #12 of 18 Old 05-09-2021, 08:51 PM Thread Starter
davetron
davetron's Avatar
What exactly is that part boogie?
2003 Jeep Wrangler
davetron is offline
post #13 of 18 Old 05-10-2021, 12:11 AM
TheBoogieman
The selector knob. They crack from behind and stop things from working properly.
post #14 of 18 Old 05-10-2021, 06:18 AM
2jhanna
Mine was cracked too, some super glue and a small zip tie around it has kept it working.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #15 of 18 Old 05-10-2021, 07:24 AM
TheBoogieman
I did the same thing and it broke again. $6 Dorman part at Autozone or Advance Auto.
