help!! Throttle stuck open - JeepForum.com
post #1 of 15 Old 05-25-2013, 05:28 AM Thread Starter
agentsmith23
It is raining like crazy here in san antonio. Went out to splash around a little and everything was going fine. Stopped for gas and now my throttle seems to be stuck wide open. I did druve through a road that brought water into the jeep. Had about 2 inches in the floorboards.
agentsmith23 is offline
post #2 of 15 Old 05-25-2013, 05:29 AM
Sandhara
open the hood and un stuck it
99 Wrangler Sahara 5spd manual - Mine
08 Patriot sport 4x4 auto - Wifes
92 Cherokee Lorado auto - for when mine needs fixin/winter beater
Im sorry, some times i drink and post stupid comments.
Sandhara is offline
post #3 of 15 Old 05-25-2013, 05:32 AM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
Have you been drinking this morning?
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
GOT IT BACK 6/17. 03' Rubicon/Zone 4.25" combo lift with 4" lift coils up front/Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
TheBoogieman is offline
post #4 of 15 Old 05-25-2013, 05:32 AM
Sandhara
naw, just got up. saw the help! and that's the first thing that came to mind to fix the current problem
Sandhara is offline
post #5 of 15 Old 05-25-2013, 05:35 AM
TheBoogieman
Distubed Jeepaholic
JK.I hope he has enough common sense to check the throttle cable linkage to un stuck it.
post #6 of 15 Old 05-25-2013, 05:47 AM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
being that you have a cable actuated throttle body, id hit it with something like your hand and make it stop. you can also use your key to turn the jeep off while you diagnose.
My builds:
and
or follow us on
spyder6 is offline
post #7 of 15 Old 05-25-2013, 05:56 AM
TheBoogieman
Distubed Jeepaholic
post #8 of 15 Old 05-25-2013, 06:09 AM Thread Starter
agentsmith23
I made it home. And yes I checked the throttle linkage and it was moving freely. All the way home though when I stopped the rpms would go up to 2-4k for a bit then drop back down.
post #9 of 15 Old 05-25-2013, 06:13 AM
M109pilot
Tps?
M109pilot is offline
post #10 of 15 Old 05-25-2013, 06:18 AM
wwch99tj
wwch99tj's Avatar
first thing I would check is, pull the throttle body off and clean it and the idle air control valve really well. The IAC might be stuck open... You can unplug the throttle position sensor to rule that out. Any check engine light?
Sent from my Galaxy Tab
wwch99tj is offline
post #11 of 15 Old 05-25-2013, 06:25 AM Thread Starter
agentsmith23
No check engine light. I am going to have to wait for it to stop raining like crazy before I can do anything.
post #12 of 15 Old 05-25-2013, 11:28 AM Thread Starter
agentsmith23
I figured it out and I feel stupid now. I have hard plastic floor mats and it was full of water. I took it out to get rid of the water and when I put it back in I didnt realize I had it sitting on the skinny pedal. DOH!
post #13 of 15 Old 05-25-2013, 11:45 AM
wwch99tj
wwch99tj's Avatar
Don't feel bad I've done that
Sent from my Samsung Galaxy S3 using JeepForum
wwch99tj is offline
post #14 of 15 Old 05-25-2013, 01:21 PM
TheBoogieman
Distubed Jeepaholic
Two idiots doesn't make it right.My Jeep sags on the passenger side and my new GF weighs 300lbs.What should I do?
post #15 of 15 Old 05-25-2013, 07:29 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
assuming you weigh about the average for a man, get a 120lb girlfriend for the other side. if you weigh more than average a sheep or medium dog may be acceptable substitute for second girlfriends. also depending upon location.
ratmonkey is offline
