help savvy aluminum control arm length - JeepForum.com
post #1 of 14 Old 10-15-2015, 06:16 PM Thread Starter
MyToyWifesJeep
I have a 98 tj with about 4.5" of suspension lift, f8.8 and sye kit with stock control arms. I want to buy the full control arm savvy kit.
Can anyone tell me the full adjustable length, from hole to hole shortest length and longest length?
and will i notice a difference in my ride?
MyToyWifesJeep is offline
post #2 of 14 Old 10-16-2015, 02:59 AM
RDaniel2405
RDaniel2405's Avatar
Why don't you call them and ask.
OEF Veteran & owner of a 2006 TJ
Instagram @theorangejeep
Pirate 4x4 @theorangejeep
RDaniel2405 is offline
post #3 of 14 Old 10-16-2015, 04:23 AM
biffgnar
biffgnar's Avatar
Unless you can find someone who hasn't yet installed them, the only length you are going to get is what someone has them currently set at. What is your concern? They will work fine with your setup.
biffgnar is offline
post #4 of 14 Old 10-16-2015, 05:25 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
someone can tell you what lengths they used on their rig, but they can't tell you what you need to use on your rig. You need to figure that out for yourself by setting up your suspension properly.
yes, you will.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #5 of 14 Old 10-16-2015, 06:28 AM Thread Starter
MyToyWifesJeep
Biggest concern is will they work if I want to go bigger? And I would like to move my re end back about a 1". Would I be able to do that with all the arms being adjustable?
post #6 of 14 Old 10-16-2015, 06:44 AM
Denzien
Denzien's Avatar
With adjustable upper and lower arms, I can't see why not. Do you currently have stock control arms?
2006 LJ
2013 MINI Cooper S Convertible, Highgate Edition
2014 Honda Odyssey Touring
Denzien is offline
post #7 of 14 Old 10-16-2015, 06:56 AM
Melissas6570
Well I am not sure why you want to go bigger, but as a personal preference, I would not go over 4 inches of lift on the suspension side. I would add a 1 inch body lift if I wanted to go up more. As far as moving the rear back an inch, it depends on your jeep. Install the arms, remove the springs and cycle the suspension. If it hits something adjust and do it over. You have stock arms now, I believe, so set the new ones up to that length to start. You should be able to get away with the front lowers at 16 inches to start with and adjust from that point based on cycling your suspension. When you do this remove the factory foam bump stops because they will fully compress and look at it at full bump. Make adjustments from that point based on what hits first. Remember there is no magic number for setting the arm length, just remove one arm at a time and replace with the new arm. place a bolt in one end and float the other end over until you can install the bolt with your fingers. Do this with the weight on the jeep. After that raise the jeep pull the springs and cycle the suspension. Make the adjustments as needed.
I DO IT WITH MY TOP OFF!
Melissas6570 is offline
post #8 of 14 Old 10-16-2015, 11:14 AM
keyster
The lowers are 15 5/8"
Uppers 12 5/8"
Center to center collapsed.
The instructions say 3/4" exposed thread maximum, so add 1.5" for max length.
The instructions give the usual lengths as 15.75" and 13.5".
I can't tell you anything about the ride yet.
I am in the middle of Rubifying my poor old Sport.
It's a Jeep thing.
keyster is offline
post #9 of 14 Old 10-16-2015, 11:52 AM Thread Starter
MyToyWifesJeep
Yes
Thanks and I will try this I should have my control arms in 2 to 3 weeks
I won't go any taller I just want to put new front coils on it and bilstein 5100s on it also metal cloak fenders
post #10 of 14 Old 10-16-2015, 11:58 AM
crkid
The lowers go down to about 15.5". Not sure how far they are at full extension. I would say up to 16.5". Not sure about the uppers.
crkid is offline
post #11 of 14 Old 10-16-2015, 02:07 PM Thread Starter
MyToyWifesJeep
thanks this is what im curious about
post #12 of 14 Old 10-16-2015, 03:14 PM
biffgnar
biffgnar's Avatar
If you do it right you may actually end up pulling your axle slightly forward at ride height. Don't sweat an inch or two either way. Will not make a measurable difference in performance.
As far as how big can you go, my rear driveshaft sees the equivalent of 8-9" of lift and had no trouble dialing in pinion with a combination of Savvy and Currie arms.
biffgnar is offline
post #13 of 14 Old 10-16-2015, 03:54 PM Thread Starter
MyToyWifesJeep
Thanks and i figured i would be good with my teraflex sye and cv shaft
post #14 of 14 Old 10-16-2015, 04:15 PM
TJDaveX
TJDaveX's Avatar
....and will i notice a difference in my ride?
I noticed a huge difference. But, I went cheap on my first set of adjustable control arms. "Flex Joint" on one end, rubber bushing on the other.
The Flex Joints needed constant attention, and I rebuilt them with the "new" delron upgrade kit. Then, the rubber bushings on the other ends started disintegrating. They always squeaked and creaked. Clunking and throttle activated lane changes started when the rubber ends wore out.
I replaced all 8 with Savvy aluminum double adjustable arms about 8 months ago along with Currie's front axle upper mount JJ conversion kit. The Jeep rides like it's on rails now. Quiet and solid feeling.
Should of ponied up and bought these the first time. Live and learn.
TJDaveX is offline
control arms , johnny joints , suspension
