HELP metal popping sound while turning left or right only when accelerating - JeepForum.com
post #1 of 10 Old 11-15-2009, 07:50 AM Thread Starter
delpster05
i have a 02 tj sport with 44re and have this popping sound comes from the rear and i can feel the rearend shift when it pops and hear metal grinding when it pops. i have the rough country 6in lift with a sye and cv just got put in a couple months ago and im running 33x12.50 still. the rear track bar that is the stock one with the rough country bracket is leaving marks on gas tank skid plate but its not loose at all i cant even move it with a pry bar when i try. i know i have the wrong bolt in the track bar mount to the rearend but i don't think it would cause it to twist in the bushing. but anyways yesterday just going down the highway my jeep starts viberating when i was doing 60mph and i could barely control it going from right to left so much in the rear. i checked everything out and it looked the same as before so i rolled away slowly and no vibes until i hit 50mph and i kept pulling over cause the vibes wouldn't stop until i slowed down to 10mph and then i kept repeating this till i got home and everything is still tight so i trying to find out if anyone else has this problem and i have a rear adjustable track bar and new bracket on order still hasn't came yet im in hawaii
delpster05 is offline
post #2 of 10 Old 11-15-2009, 08:52 AM
nptt13
DOOD I had the same problem... I thought it was suspension or traction related... ITS NOT ... Pop open your rear differential cover, then check your Spider gears for broken teeeth. If you dont see any, check the bottom of the inside of your case and you may find some teeth, hurry and do this before anymore break. Im doing it now as we speak. Not expensive fix at all. If you want to see what it looks like, do a search on youtube and youll find nice vids on people pulling tons of broken teeth outta the differential.
John
Got Milk?
nptt13 is offline
post #3 of 10 Old 11-15-2009, 11:10 AM
dogbluedrummer
Trust me....
dogbluedrummer's Avatar
Could be the limited slip. Chang your diff fluids. Be sure to add the friction modifier.
Patriot Blue 2001 TJ
Everything I need to fix on the heep: ABS indicator, speed 4 on the blower fan, torn softop over driver's head, both seat release/tilt cables, missing center cap on spare, broken under hood light, wire up the CB, wiring problem with the reverse lights, broken bottle jack, leaky front and rear pinion seals, loose trackbar relocation bracket, torn drivers seat on the side, broken center console lock, lost nuts for door hinges, squeaking centering ball, loose parking brake cable, oil change and rotate the tires.
My build thread
dogbluedrummer is offline
post #4 of 10 Old 11-15-2009, 11:10 PM Thread Starter
delpster05
i tightend the trac bar down and it tightend some so i took for a test drive and it was fine with no vibes but after 20 min it started to pop again around turns so it cant be the teeth can it or limited slip but im gonna pull the diff cover tom but until then i gotta run it but what kind of fluid should i get or friction modifier? and i just changed the fluid out before i did the lift a couple of months ago
post #5 of 10 Old 11-16-2009, 07:44 AM
nptt13
Most synthetic gear oils like Valvoline make already have it mixed in. Just go to Pep Boys or any local parts store and you should be able to pick it up for 3 - 6 bucks
Got Milk?
nptt13 is offline
post #6 of 10 Old 11-16-2009, 07:53 AM
chutta
You have to do periodic inspections of the pig, not only to change out oil, but to avoid carrier breaks by "nipping it in the bud" so to speak checking on the spiders. Don't ask
05x 4.0 6sp 30/35, aussie front, 3.73's, r/c 4"x lift, adv adptr sye, shifter bracket, tw cv ds, 33 t/c skid, 33x12.5 dunlop mud rovers on steelies, psc sport cage/rockers, warn fr bump/steer and 30 diff skid, sirius,cb, hand throttle 1"bl/mml 265/16's pepboys at's on orig moabs for street. Lowrance H20c for gps
chutta is offline
post #7 of 10 Old 11-22-2009, 01:27 AM Thread Starter
delpster05
yea i got missing teeth in my gears the dealership said i have a 44 in the rear and a 30 in the front could that be right? and 3.73 gears but now i need gears so i found some 4.10 to hold me over until the 4.88 get ordered and just regear now the price was right for the 4.10
post #8 of 10 Old 11-22-2009, 03:58 AM
dynastynut
Yes they are right, dana 44 in the rear, and a dana 30 up front
dynastynut is offline
post #9 of 10 Old 11-22-2009, 07:02 AM
nptt13
I went through the same thing. What was kewl about Jeep TJs is they had a 7/70 warrantee on the transmition which includes the differential. Look into it. It could save you a few hundred dollars. All mine cost was 100 dollars and the dealership let me drive a loaner car in the mean time no extra charge.
Got Milk?
nptt13 is offline
post #10 of 10 Old 11-22-2009, 11:18 PM Thread Starter
delpster05
its just time to upgrade
popping sound when accelerating Crockett TJ Wrangler Technical Forum 7 02-09-2010 11:49 AM
Rear end popping and clunking when turning and accelerating chaznad TJ Wrangler Technical Forum 7 06-13-2009 04:30 PM
metal popping sound when turning fate1630 TJ Wrangler Technical Forum 7 04-15-2009 07:38 PM
Popping when turning left and right rubbertoe TJ Wrangler Technical Forum 6 02-19-2009 07:53 PM
Weird popping noise while turning left...? romanella YJ Wrangler Technical Forum 3 01-09-2008 07:44 AM
