Help me pick a new Camshaft. - JeepForum.com
post #1 of 8 Old 12-01-2010, 09:09 PM Thread Starter
Travis_
I was going to get a Cam from Autozone (Melling MC1377). Then I realized maybe I should just go with a slightly high performance Cam.
I looked at the Hesco RVOB6 but decided not to after I realized the head needed to be machined and I needed to replace all valve train components accept the rockers.
Then I found the mopar performance Cams. So far I am liking the P4529228ab Cam since I dont have to replace any valve train component accept the lifters which it comes with.
There is also P4529229ab Cam which from what I understand I will need to replace valve springs if used.
Right now I have narrowed it down to the Melling or the Mopar's. Anyone have any suggestions. I am leaning towards the P4529228ab since it seems to work in the lower RPM 900-4700.
08 Unlimited Rubicon 6spd
06 Rubicon 6spd: 4 sale
04 Grand Cherokee Limited V8 w/Quadra-Drive
Travis_ is offline
post #2 of 8 Old 12-01-2010, 09:31 PM
Ej132
Subscribed
Ej132 is offline
post #3 of 8 Old 12-02-2010, 12:27 AM
RockRodHooligan
Blood, Sweat, and Gears
RockRodHooligan's Avatar
Comp Cams 68-323-4
96 XJ:
89 MJ: Project: Ground up - Sold
01 XJ: Project: Silverback - Totaled
***** inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
RockRodHooligan is offline
post #4 of 8 Old 12-02-2010, 06:16 AM Thread Starter
Travis_
thanks I'll have to give them a call and see what I need
Travis_ is offline
post #5 of 8 Old 12-02-2010, 08:01 AM
RockRodHooligan
K68-232-4 is their cam and lifter kit, that includes the cam, lifters, timing set, valve springs, stem seals, retainers, and locks, BUT I've looked it up in their book, and web site, and it had a side note about the "K" kits:
K-kits will only work in 1964-88 models due to different valve stem.
Not sure how much of a difference the 258(4.2L) valve stems have compared to the 4.0L's but worst case scenario is that you would need to source your own stem seals, locks, and retainers. They should be able to give you more info.
Edit:
http://www.compcams.com/Company/CC/c...x?csid=12&sb=0
96 XJ:
***** inches...
post #6 of 8 Old 12-02-2010, 08:58 AM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
If I were you I would give Comp Cams a call like stated above.
GOLENJEEPTJ is offline
post #7 of 8 Old 12-02-2010, 12:29 PM
redrubikee
redrubikee's Avatar
1972 C104
505 performance THE ONLY THING THEY DO IS JEEP 4.0 and 2.5
redrubikee is offline
post #8 of 8 Old 12-02-2010, 01:20 PM
Robert J. yates
Yah... Comp is good but check out both 505 and Hesco. My H264 Hesco cam has worked out pretty well.
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline
Crankshaft/Camshaft Pick-up Plate FIXED, PLEASE READ. jasonamorris TJ Wrangler Technical Forum 8 11-11-2016 12:30 PM
Bad camshaft in some 04 TJs PackMan TJ Wrangler Technical Forum 4 01-22-2012 12:34 PM
Clifford Performance camshaft for my 2.5L or just a regular camshaft? r_unda YJ Wrangler Technical Forum 12 04-20-2010 05:30 AM
Clifford Performance camshaft for my 2.5L or just a regular camshaft? r_unda TJ Wrangler Technical Forum 7 04-19-2010 12:59 PM
2.5L Camshaft? jaybird02 TJ Wrangler Technical Forum 1 03-19-2008 09:44 PM
