Help me identify this - JeepForum.com
post #1 of 10 Old 04-26-2020, 01:12 PM Thread Starter
173djeep
I recently had high idle when in park after washing around my engine bay. I was looking for a vacuum leak when I noticed this plug just dangling. Does anyone know where this should plug in to? Thanks
173djeep is offline
post #2 of 10 Old 04-26-2020, 01:13 PM Thread Starter
173djeep
Here’s another picture
173djeep is offline
post #3 of 10 Old 04-26-2020, 06:20 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
What are the wire colors?
Rubi4MyMrs is offline
post #4 of 10 Old 04-27-2020, 09:05 AM Thread Starter
173djeep
They are black.
173djeep is offline
post #5 of 10 Old 04-27-2020, 01:21 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
I can’t recall anything with 2 wires which it appears you have, that has both being black. Two blacks could indicate it’s not OEM. It’s hard to tell from the photos but looks like it is original. Is it possible it is a pigtail to something & looking back toward the main harness there is a connector that might have other color wires coming to it?
It looks like it is above the starter & near the battery. There should be a temperature sensor under the battery but that should have brown/yellow & pink/yellow wires.
post #6 of 10 Old 04-27-2020, 02:16 PM
Jonny Jeep
Jonny Jeep's Avatar
It doesn't look like it's long enough to be for an under hood lamp to me, which would have pink/white and black wires. Looking at the state of the plug I can't help thinking the 'black' wires might just be filthy.
See if the wires will wipe clean at all. If they are dark blue/white and dark blue/orange they would be A/C low pressure switch.
Jonny Jeep is offline
post #7 of 10 Old 04-27-2020, 04:51 PM Thread Starter
173djeep
You were right, the wires were just extremely dirty.
173djeep is offline
post #8 of 10 Old 04-27-2020, 06:01 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Good call, Jonny.
post #9 of 10 Old 04-27-2020, 06:27 PM
TJ4Jim
Could be the AC low pressure switch if you're not equipped.
If you come to a fork in the road take it.
TJ4Jim is offline
post #10 of 10 Old 04-28-2020, 08:46 AM Thread Starter
173djeep
My Jeep doesn’t have AC. Thanks guys
173djeep is offline
