Help me find linkage for A/C mode selector switch. - JeepForum.com
 1Likes
  • 1 Post By CGrugger
post #1 of 9 Old 05-31-2020, 02:27 PM Thread Starter
CGrugger
CGrugger's Avatar
So my A/C mode selector works for defrost and feet, but not the face. I tracked the issue down to the plastic connector that connects the vacuum actuator to the dampener, right behind the cigarette lighter.
I have checked all the parts stores, rockauto, wermopar, etc and can't find it. The local pick-n-pull only has a 98, but that uses a different style.
Does anyone know where I would be able to local this part. See attached pictures to see what I am talking about.
Sent from my Pixel 2 XL using Tapatalk
2005 TJ X: MC 3.5" lift, 33"x12.5" tires, 1.25" Zone body lift, Curry Antirock sway bar.
CGrugger is offline
post #2 of 9 Old 05-31-2020, 05:52 PM
CTR
I got mine off amazon but look different than those, I’ve read people super glued them back in but I’d rather change it
97 Wrangler SE auto, stock
CTR is offline
post #3 of 9 Old 05-31-2020, 07:40 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
I have not had mine fall out or break so not sure what the late ones look like so I have to ask what is wrong with that one?
Here is a co. that makes the early ones but a search might find they have the later ones too.
Omix-Ada 17910.01 (replaces 4886086AB)
Omix-Ada 17910.02 (replaces 5014108AA)
& on Google
https://www.google.com/search?q=Omix...A&ved=0CC4Qsxg
Hope this helps. It is somewhat common for the early ones (shown) to fall out & may be held in with a sheet metal or drywall screw. I have not seen problems with the later type. If you find them, post results here.
Rubi4MyMrs is offline
post #4 of 9 Old 06-01-2020, 02:31 AM
sycboi
It is broken where I circled. It should mirror the arm that’s still there. They go inside the hole and snap in place with the nubs on the end retaining the parts together...
SuperBeast, enforcer for the Mopar Mafia ̿ '̿'̿\̵͇̿̿\з=(̪●)=ε/̵͇̿̿/'̿'̿ ̿
sycboi is offline
post #5 of 9 Old 06-01-2020, 10:34 AM
Rubi4MyMrs
Rubi4MyMrs's Avatar
The early ones used only 1 barb but are you saying the later ones use 2 & one of them is broken off?
And without the 2nd one it will just fall out, right?
post #6 of 9 Old 06-01-2020, 05:06 PM Thread Starter
CGrugger
CGrugger's Avatar
Hey, thanks for the links and replies!
Yeah, without the second barb it just falls out.
I figured I could just glue it in, but would rather actually fix it.
The earlier models have a different set up. They have a white arm that is shorter.
I will have to dig into those links after dinner.
CGrugger is offline
post #7 of 9 Old 06-03-2020, 08:36 PM
rcroane
Have you tried Davey's Jeep?
rcroane is offline
post #8 of 9 Old 06-04-2020, 05:14 AM Thread Starter
CGrugger
CGrugger's Avatar
That is on my list of places to call. I did reach out to Collins brothers, but haven't heard back. Thanks.
CGrugger is offline
post #9 of 9 Old 06-05-2020, 07:28 PM Thread Starter
CGrugger
CGrugger's Avatar
Davey's had that part on hand and I got it shipped. Davey was super fast to respond and great to work with.
rcroane likes this.
CGrugger is offline
