Help! I need help identifying part (coolant leak) - JeepForum.com
 1Likes
  • 1 Post By Leans93
post #1 of 5 Old 07-22-2021, 04:48 PM Thread Starter
Laaaysuh
(Sorry if this is the wrong forum)
I need some help! I’m no grease monkey but I always try to figure out what went wrong before I go to my mechanic… I have had coolant/radiator issues before but this one is new. Looks like it’s coming from this hose… hopefully nothing else.. but whatever. Coolant in reserve… not hitting fan but is blowing out and hitting the underside of the hood and coming out the passenger side of the hood onto the fender… anyone know what this particular part is or how to patch it? Entire new hose? More? Help!
Laaaysuh is offline
post #2 of 5 Old 07-22-2021, 09:52 PM
Leans93
She's my density...
Leans93's Avatar
Looks like you’re pointing at an A/C refrigerant hose. Compressor to condenser maybe. How cold is your A/C?
Wyo likes this.
M.F. Leans
00’ TJ 4.0L Auto, 2.5” Skyjacker lift, 33x12.5x15 BFG AT’s, and some other stuff
93' YJ 4.0L AX-15, 4" Pro Comp lift, 3/4" shackles, 1" BL, 33x12.5x15 BGF MT's, and some other stuff
Originally Posted by Mike Jones
Catch me on the highway or about to tear the mall up.
Leans93 is offline
post #3 of 5 Old 07-22-2021, 10:30 PM
Wyo
Wyo's Avatar
Yup that is an AC line to the condenser/ You will need a new one and a Vac and a recharge of the AC.
Wyo is offline
post #4 of 5 Old 07-23-2021, 07:25 AM
LumberjackLloyd
Had to replace this recently on my 99, fairly simple job. Be careful not to allow any contaminants into the system.
LumberjackLloyd is offline
post #5 of 5 Old 07-23-2021, 09:38 AM
TJ4Jim
If you are sure it's coolant then it is not coming from that hose, most likely a drip from the weep hole on the water pump. Take a close leak at the front of your oil pan near the top to see if any coolant is present.
If you come to a fork in the road take it.
TJ4Jim is offline
