Help with gear ratio and speedo gears.. - JeepForum.com
post #1 of 6 Old 05-13-2008, 03:58 PM Thread Starter
simplybao
Guest
I think that I have 3.07 gears but am not sure. Here's a link to the tag that is on the front differential cover.
Assuming that I have 3.07 gears which speedo gear do I need to get? I'm running 31x10.5 BFG's. Based on
http://www.4x4xplor.com/speedo.html
It looks like I need part number 52067627 i.e. 27 teeth
This is the tag on then diff cover:
simplybao is offline
post #2 of 6 Old 05-13-2008, 04:16 PM
Todd4a
Looks like a 3.07 to me.
Todd4a is offline
post #3 of 6 Old 05-13-2008, 04:19 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Yep, a 27 tooth is what you want and the tag confirms you're running 3.07 axles.
Jerry Bransford is offline
post #4 of 6 Old 05-13-2008, 04:53 PM Thread Starter
simplybao
Guest
SWEET! Thanks for all the responses. So now my question is, I see alot of people re-gearing to 4.10 and higher. Is it worth it for me to re-gear? I may be just mis-informed but isn't a 3.07 not very desireable?
post #5 of 6 Old 05-13-2008, 05:07 PM
Jerry Bransford
Administrator
A 3.07 ratio generally makes a Jeep a real dog. Regearing is a commonly done thing that can completely transform a Jeep once bigger tires are added. However, at the $1200-1300 it typically costs, you don't want to spend the $$$ until you're at a tire size that you think you'll be staying at for a while. For 31" tires, I don't think I'd regear yet. But if you get tires bigger than that, then it's time to regear to a lower ratio. Auto trannies are far more forgiving of mismatched tires sizes and ratios so if you're fortunate enough to have an auto, that will help.
post #6 of 6 Old 05-13-2008, 05:59 PM Thread Starter
simplybao
Guest
Cool, thanks for the guidance!!! I have a requirement to stay at my 2" lift and 31's...the other half has dictated no higher
But I've been contemplating getting Rubicon axles for front and rear so if I did that, then I'd get them with 4.10's.....
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 06:58 PM
2?'s Which speedo gear and actual gear ratio maxum3300 TJ Wrangler Technical Forum 6 01-15-2010 06:40 AM
is this correct? (speedo gear for 33s w/ 4.88 gears) zband TJ Wrangler Technical Forum 11 05-30-2008 02:45 PM
what speedo gear for 4.56 gears and 35's? MikieB TJ Wrangler Technical Forum 10 09-07-2006 06:55 AM
GEARING RATIO/Speedo gear... Bheleu33 YJ Wrangler Technical Forum 16 04-15-2006 05:04 PM
