Help! 2.4L Turbo - JeepForum.com
 3Likes
  • 2 Post By jtec
  • 1 Post By 4Low2G0
post #1 of 7 Old 08-08-2020, 10:37 PM Thread Starter
Speedster98
Help! 2.4L Turbo
I am looking at buying a 2003 wrangler with an added 2.4L turbo. However, I have a few questions. Do they tend to last pretty well, or do they end up with too many problems down the road? I don't want to waste my money on something that will be expensive to maintain later on. The turbo has been used for less than 400 miles. Are there any questions I need to make sure to ask the seller?
Speedster98 is offline
post #2 of 7 Old 08-09-2020, 12:04 AM
4Low2G0
4Low2G0's Avatar
Factory Turbo Engines have lots of upgrades over N/A engines. A N/A engine with a turbo added
can work with low boost, but will not live as long a life.
Low speed off road work needs torque, turbo needs RPM to build boost.
crawling low RPM, a turbo won't help. Mud or sand a turbo can work.
N/A and Turbo/Boosted engines are built differently.
https://en.wikipedia.org/wiki/Chrysl..._and_2.4_Turbo
How do you plan on using YOUR Jeep?
Whats over that next ridge?
4Low2G0 is offline
post #3 of 7 Old 08-09-2020, 12:17 AM
jtec
jtec's Avatar
2014 JK Wrangler
Short-
I suggest you pass on this vehicle.
mukluk and 4Low2G0 like this.
jtec is offline
post #4 of 7 Old 08-09-2020, 02:41 PM Thread Starter
Speedster98
I would plan on using it as a daily driver for short commutes and a fun extra vehicle just to cruise around in. I am not planning on doing any offroading with it. I just want it to be able to go highway speeds up a hill or against the wind, which was my problem with my old 2004 wrangler. The turbo that was put in it is a Garrett T25.
post #5 of 7 Old 08-09-2020, 03:26 PM
4Low2G0
4Low2G0's Avatar
Originally Posted by Speedster98 View Post
I am looking at buying a 2003 wrangler with an added 2.4L turbo. The turbo has been used for less than 400 miles. Are there any questions I need to make sure to ask the seller?
Why selling after only 400 miles?, this is a major red flag to me.
mukluk likes this.
4Low2G0 is offline
post #6 of 7 Old 08-09-2020, 03:30 PM
mukluk
mukluk's Avatar
The seller probably can't get it to run right would be my guess and has decided to offload instead of dealing with the headache.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #7 of 7 Old 08-09-2020, 05:44 PM
4Low2G0
4Low2G0's Avatar
Right, Giant red flag....
And I will say again a N/A engine is built with different tolerances and specifications.
yea you can slap a turbo on an old engine and it will run.....for a while..
not to mention passing any inspection that may or may not be required...
4Low2G0 is offline
