help 04 TJ won't crank - JeepForum.com
 4Likes
post #1 of 23 Old 09-18-2020, 12:31 PM Thread Starter
wdrakos
2004 TJ SE won't Crank, battery is fine, replaced the starter, still won't crank. anyone else have this issue?
wdrakos is offline
post #2 of 23 Old 09-18-2020, 12:40 PM
2jhanna
If it's an automatic, could be nss, neutral safety switch. Try it in neutral.
Manual, could be clutch switch.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #3 of 23 Old 09-18-2020, 01:04 PM
jtec
jtec's Avatar
2014 JK Wrangler
As mentioned above is this an automatic or manual?
Easiest, for me anyway, is to check at the starter relay, does relay click when key moved to start?
is there 12v when key in start B5?
is B3 a good ground?
Is there 12v B1?
jtec is offline
post #4 of 23 Old 09-18-2020, 01:52 PM Thread Starter
wdrakos
Standard transmission, Relays have the appropriate voltage, I'm in the process of tracking down a clutch switch to try and change that out.
wdrakos is offline
post #5 of 23 Old 09-18-2020, 02:13 PM
2jhanna
Our TJs have a feature called "clutch over ride". By inserting a 20a fuse in slot 20 behind the glove box, this will disregard the clutch switch.
Pretty dangerous if you think about it, but it lets crank the vehicle without depressing the clutch. This allows you to walk yourself out of the mud if your engine dies.
May want to double check your 04 manual but that's the location for my 02.
Put a fuse in the slot, either depress the clutch or make sure you're in neutral, and give it a try.
Edit, the fuse in slot 18 is a spare just for this purpose, so you can just move it from 18 to 20, for this test.
jhanna
denton county, tx
2jhanna is offline
post #6 of 23 Old 09-18-2020, 02:25 PM
jtec
jtec's Avatar
2014 JK Wrangler
IIRC the clutch pedal switch (CPPS) is part of clutch master SO might want to be sure its bad.
following above suggestion see attachment - not a recommendation but a get you going idea
note the spare is right next to the bypass #20. in fuse F19
jtec is offline
post #7 of 23 Old 09-18-2020, 02:36 PM
2jhanna
Jtec, so the 04s fuse box is different than a 02s ???
jhanna
denton county, tx
2jhanna is offline
post #8 of 23 Old 09-18-2020, 02:39 PM
mukluk
mukluk's Avatar
If this statement is meant to say the starter relay is getting voltage at both appropriate terminals, one for the power feed that connects to the starter when the relay is energised and one for the operation of the relay's solenoid, then the problem cannot be due to the clutch interlock/safety switch. This switch interrupts or completes the power feed side of the relay control circuit. If you're getting good power on those two feeds but the relay is failing to energise, then the ground side of the relay control circuit is open. If the feeds are good and the relay is energising when the key is turned (you can hear or feel it click), then either the relay contacts are bad or the feed wire from the relay output going to the starter is faulty.
NashvilleTJ and jtec like this.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #9 of 23 Old 09-18-2020, 04:44 PM
jtec
jtec's Avatar
2014 JK Wrangler
2jhanna can't say 02 and 04 wiring is same - I was online doing work so it was an easy click click to get 04 diagram.
jtec is offline
post #10 of 23 Old 09-19-2020, 08:21 AM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
I learn something every day on this forum.
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
post #11 of 23 Old 09-19-2020, 08:45 AM
2jhanna
This topic got me thinking, is there any reason a manual TJ can’t be push started? Get it rolling good and let the clutch out.
jhanna
denton county, tx
2jhanna is offline
post #12 of 23 Old 09-19-2020, 12:03 PM
mukluk
mukluk's Avatar
You can push start a TJ, just so long as the battery isn't dead. The PCM has to have juice in order for the engine to fire and for the alternator to work.
2jhanna likes this.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #13 of 23 Old 09-19-2020, 12:46 PM
PDoyle
PDoyle's Avatar
Probably want to make absolutely sure the battery is good, IMO.
2003 X, 5 speed, FT/RR bumpers by Eddie Reighard. JKS 1" body lift, JKS disco's, 2 1/2" Rough Country lift, 8k Warn, w/class 3 receiver FT & RR hitch. GA 8 rims riding 33's- GY Kevlar.
SOLD- 1985 CJ7 soft top , fiberglass body, 5" total lift258-6- Howell TBI, Full Roll cage.
PDoyle is offline
post #14 of 23 Old 09-19-2020, 08:55 PM
Dale M.
My 02 TJ lost ground from manual trans C154 connection and would not crank..... Check to see if there is a ground on the B3 terminal of starter relay socket...
As a test you can also remove starter relay and jump B1 and B2 terminal in relay socket and it should spin up starter BESURE YOU ARE IN NEUTRAL....
Dale
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Dale M. is offline
post #15 of 23 Old 09-19-2020, 09:43 PM
2jhanna
The OP hasn't been back since 3:00 yesterday.
jhanna
denton county, tx
2jhanna is offline
